Author Topic: 571  (Read 264535 times)
Re: 571
« Reply #105 on: May 27, 2014, 11:00:54 AM »
ah, appears there's a special type for power washers with a fitting for garden hose inlet. 10-4 & thanks google
Re: 571
« Reply #106 on: May 27, 2014, 11:25:51 AM »
ya, it goes right on the inlet.  i shoot it in, then slow crank the pull cord, then shoot it in again.
Re: 571
« Reply #107 on: May 27, 2014, 01:11:19 PM »
My pressure washer guy says windshield washer fluid is fine. The cheaper the better.
I just reuse the special bottle of pump guard I got from depot with the shut off and garden hose fitting.
Re: 571
« Reply #108 on: May 27, 2014, 10:16:45 PM »
home depots power washers are around $300 with a honda engine, ive had it 6-7 years now and have never touched a thing and only maintenance is run it out of gas before winter
Re: 571
« Reply #109 on: May 28, 2014, 07:22:08 AM »
Finally cracked a plastic fitting in my pump this past winter.  $10 and it's good-to-go again.
Re: 571
« Reply #110 on: May 28, 2014, 02:25:36 PM »
Jim said he will look and fix trans very quickly once he gets it.  Says probably seal failure from heat.  Clutches should not be worn at all yet.
advises sustained temp 220 continuous, 260-80 max intermittent.
we talked about different manual valve body options, i think you need to talk to him to straighten that out.
Re: 571
« Reply #111 on: May 28, 2014, 03:20:37 PM »
seems good, thanks.
Not sure what my schedule on getting it pulled out yet is. blah blah unneeded details. Beem making good progress around the house, almost ready to make use of the garage again (in the ready to clean it up fashion).
Re: 571
« Reply #112 on: May 29, 2014, 09:56:10 PM »
Cannot find vac leak.
May just replace intake manifold gaskets and dbl check injector orings. Not sure what else to try. Verified it's not one of the actual vacuum lines.
Trans temp gauge problem is the sender. The spare I have doesn't have compatible ohm ranges so I need to swap both pieces to make it work. After verifying gauge function and then checking the sender (it spins where it shouldn't), I misplaced the vdo sender. Mother. Fucker.
So, all told, I drove it out of the trailer and back in again. Productive night.
Re: 571
« Reply #113 on: May 29, 2014, 10:53:59 PM »
i have a new gage some where, from replacing the sender once before.  Gaurentee it was carless install that broke the sender.  in a stupid place.
Re: 571
« Reply #114 on: May 30, 2014, 07:36:31 AM »
I keep hoping this will fix mine ;D
Re: 571
« Reply #115 on: May 30, 2014, 11:42:20 AM »
pull this trans out already- this isnt the dakota!
Pull it saturday night / sunday, i can help if you want.  Jim will have it back fixed wednesday, race saturday.  quitchyour bitchin baller buggy boy
Re: 571
« Reply #116 on: May 30, 2014, 01:30:46 PM »
Lack of workspace keeps me bitching. I'm running on Sunday. Need anything to/from downstate, anyone?
I'm more worried about the un findable vacuum leak than a known trans thing at this point. Think manifold gaskets are a reasonable next step?
Re: 571
« Reply #117 on: May 30, 2014, 02:04:34 PM »
i dont know the procedure used- contamination, improper torque, or oring damage from installation would be my first guess before gasket failure.
Re: 571
« Reply #118 on: May 30, 2014, 02:56:00 PM »
I didn't torque super carefully. They were cleaned but not lubed. Surfaces were cleaned. It was all FILTHY to begin with including some rather crusty deposits on the head side.
Re: 571
« Reply #119 on: May 30, 2014, 03:06:03 PM »
the torque really isnt so important- i found that following the sequence is more important in the thousands i bolted down and did back fire / burst tests on....
