Author Topic: 571  (Read 264519 times)
Re: 571
« Reply #135 on: July 02, 2014, 09:35:21 AM »
So it was running lower line pressure than it could/should have been. More slip, more heat, badness.
sounds promising, and like an explaination of the fast failure.
Hopefully gauges and pan arrive today, I should check shipping. Going to be a busy day at work and have some other running to do too..
Re: 571
« Reply #136 on: July 02, 2014, 09:42:55 AM »
updated.  700R4 is the trans that uses kick down for line pressure, not th350- scratch that
Jim:
I did change the valve body over from the core transmission. It worked so well before I figured it would be worth a shot. Your old 350 had a roller clutch fail. Nothing more than just being well used.
Re: 571
« Reply #137 on: July 02, 2014, 12:45:06 PM »
failure determined from running dry / heat
not much usful things left.
used most of the second core trans to build into first housing.  Built with summit valve body
input gear from trans pulled from car is BEAT up where TQ  mates- he said closely inspect TQ and or replace  :o
Re: 571
« Reply #138 on: July 02, 2014, 12:45:45 PM »
trans is in the delphi lot
Re: 571
« Reply #139 on: July 02, 2014, 01:54:39 PM »
No TC kept in stock at nuway :(
Not sure what other options might be
Re: 571
« Reply #140 on: July 02, 2014, 02:20:19 PM »
I think i have 1 or two under my apartment.
Trans in zj.  Jim comp'd all labor, and put 80$ in parts- i gave him a 100$
said to flush TQ and run the trans this weekend, then change fluid after this weekend.  If it doesn't last the rest of the year with added cooling and ok temp numbers- time either dump $$ into a custom350 full manual high pressure trans, or make room for a th400.  He really wants to help us find a solution with out multiple trans pulls- he understands intensive labor.
Re: 571
« Reply #141 on: July 02, 2014, 02:28:36 PM »
Milt and Ron's may have a converter in stock, I was just considering going down to the shop to pull the old one.
Re: 571
« Reply #142 on: July 02, 2014, 02:36:10 PM »
Re: 571
« Reply #143 on: July 02, 2014, 02:37:17 PM »
1969-1979 Chevy C10, C1500
Re: 571
« Reply #144 on: July 02, 2014, 02:43:26 PM »
Blazer   1969-1982          TH350
Re: 571
« Reply #145 on: July 02, 2014, 02:48:56 PM »
Re: 571
« Reply #146 on: July 02, 2014, 02:53:14 PM »
does that just mean you use bolts or bolts and nuts?  i dont recall what it has.
TH400 TQ looks to cross, not sure about 13" though will fit.
Re: 571
« Reply #147 on: July 02, 2014, 02:53:51 PM »
Looking at the book at Milt & Ron's, the pad/lug mount difference is the main thing, with a few having a 1/4" dia difference and an uncommon 6 pad mounting type
Re: 571
« Reply #148 on: July 02, 2014, 02:55:16 PM »
his pics were poor, but both looked to be female. He wasn't certain.
any idea the quality of what's under the shop?
Re: 571
« Reply #149 on: July 02, 2014, 02:57:15 PM »
i honestly dont recal what is what.  i believe the TH400 converter that was left open in the shop was scrapped.  if there is one under my apartment, it was left full and tapped shut.  there may be another th400 one in the transmission that is there also that is ok.
