Re: 571
« Reply #150 on: July 02, 2014, 02:57:36 PM »
They're only there till 1630, and I really don't want to rush this and fuck it up. I don't want another shit out tranny in a month either :-\
And more work just came down the pipe for me so I can't really sneak back out. May have to delay install to tomorrow unless the existing TC looks better than I fear, and I really don't want to do that.
Re: 571
« Reply #151 on: July 02, 2014, 03:05:04 PM »
Jim said TH350 and 400 are same
Re: 571
« Reply #152 on: July 02, 2014, 03:08:51 PM »
this is instock at advance for 100$
http://shop.advanceautoparts.com/p/pro-king-automatic-transmission-remanufactured-torque-converter-gm3/5990130-P?navigationPath=L1*14925%7CL2*15047%7CL3*16291#
asked jim to confirm thoughts of working
Re: 571
« Reply #153 on: July 02, 2014, 03:12:05 PM »
wont be able to confirm it fits- have to check
Re: 571
« Reply #154 on: July 02, 2014, 03:15:47 PM »
yeah it's the flywheel that matters more there. Seems all have the same spline and pilot dia, it's all the mounting that changes. Not sure about a 13" fitting in the bellhousing, but the 11.5" bolt circle seems common to the TH400/4L80E, the 10.7" bolt circle to the TH350/700R4/4L60E
Re: 571
« Reply #155 on: July 02, 2014, 03:22:37 PM »
90% sure this is whats in the car now
http://www.summitracing.com/parts/sum-g2699
Re: 571
« Reply #156 on: July 02, 2014, 03:24:30 PM »
90% sure this is what was first built in the car and what is most likely on the floor under my apartment after the first trans blew
http://www.summitracing.com/parts/bmm-20400/overview/
Re: 571
« Reply #157 on: July 02, 2014, 03:24:44 PM »
that's a match to p/n GM350 which was looking more likely. And isn't in stock at Advance
Re: 571
« Reply #158 on: July 02, 2014, 03:35:22 PM »
im going to guess that i re drilled for the 10.7 pattern, and the 11.5 pattern already exists on the flexplate-  there are 6 holes clocked 60 degrees....
Re: 571
« Reply #159 on: July 02, 2014, 03:48:55 PM »
Buy them all and take back what does not fit.
Re: 571
« Reply #160 on: July 02, 2014, 03:54:26 PM »
that was my thought ryan but its not my car anymore :)
id also like a new one in, as this hassel is not really worth 12hrs labor
Re: 571
« Reply #161 on: July 02, 2014, 04:29:50 PM »
I didn't look for the other holes when I pulled it but if they're not there, this should fit:
Re: 571
« Reply #162 on: July 02, 2014, 04:33:22 PM »
pretty blue!
Re: 571
« Reply #163 on: July 02, 2014, 04:46:49 PM »
But if those other holes are there, (and/)or if I fucked this up, the T400 p/n GM3 in stock at Henrietta Advance seems like a very solid backup plan - importantly, a plan that's open later than 4:30. So I feel pretty good about this now.
Re: 571
« Reply #164 on: July 02, 2014, 04:48:12 PM »
torque converters are like generators. No returns.
unlike generators though, they're not free. I need to visit Gander sometime and let them know they kinda fucked up bigtime at checkout... :whistle:
