Author Topic: 571  (Read 224858 times)
Re: 571
« Reply #180 on: July 04, 2014, 02:07:46 PM »
Hammered ass.  I laughed so hard I cried a little
Re: 571
« Reply #181 on: July 04, 2014, 03:56:27 PM »
I'm just plain crying. Intake mani gaskets made no difference. I'm pulling plugs.
Could be a hung lifter? I don't have a compression tester. Really behaving like a bad hole - and there did happen to be a nearly frightening amount of metallic fines on the oil drain plug.
I sure hope I get to pull the motor again to fix an internal issue or replace it, yessiree!!
Re: 571
« Reply #182 on: July 04, 2014, 04:04:53 PM »
I think I'm in love!!
Re: 571
« Reply #183 on: July 04, 2014, 10:18:23 PM »
Re: 571
« Reply #184 on: July 04, 2014, 10:28:59 PM »
No idea how that is for a price on a supposedly good unit or how sellable a used converter that's useless to me is.  input from the wise?
Re: 571
« Reply #185 on: July 05, 2014, 09:25:15 AM »
Southbound! M4 lot camp-out 100% success. Honda untested. Suspicion of annoyingly long set and strike confirmed. Definitely not more than a tempermanant configuration.
Re: 571
« Reply #186 on: July 06, 2014, 04:29:22 PM »
Broke reverse. Sounds like gnashing gears or stripped splines. AWESOME.
Re: 571
« Reply #187 on: July 06, 2014, 07:51:17 PM »
gave this some thought on the way home.
id cut the car for in cab trans removal.
F this thing.
Id order a summit trans, and give the current to jim to look at with more time.
this is crazy.   matt has beaten his 400 with heat, i wish there was room in that car, bah
Re: 571
« Reply #188 on: July 06, 2014, 07:53:35 PM »
Reverse completely silent and ineffective when I got home. Got popup unloaded and coaxed the car into the enclosed.
Thinking about modifications to make stripping the interior quicker & easier, and allowing the trans out through the passenger compartment while also allowing for fit of th400/ 700r4/ 4l60/ 4l80. I think the very biggest hurdle to all of that is tcase proximity to the tail shaft. I don't know that there's enough slip to slide the joint in to clear. All other trans options are longer, too, I believe. So the case may need to move back 4-6" and gain a short driveshaft rather than one-ujoint drive.
Not that the motor doesn't have a lil tick and had iron in the oil, but I really hope at least the next motor can outlast several transmissions. A motor without the trans attached would probably be an easier removal too. Straight up, maybe even with headers and motor mounts still attached.
Re: 571
« Reply #189 on: July 06, 2014, 08:00:38 PM »
TH350 and 4L60E are very close in length measurement.
Re: 571
« Reply #190 on: July 06, 2014, 08:06:08 PM »
i have a long tail 4l60e
lower first and over drive is a key advantage i love in my car
4.10's are great for racing but not much else  :-[
Re: 571
« Reply #191 on: July 07, 2014, 07:43:51 AM »
O/d would let lower axle gears be happier in low, and lower first and lower gears would make high useful. It would be a good improvement from that perspective.
Re: 571
« Reply #192 on: July 07, 2014, 07:59:24 AM »
I forgot to mention-the recon is dead. Solenoids make a sickly electrical noise, sometimes. That's it.
Needs a talon 9.5 replacement, and to go in the enclosed if I can fix it.
Re: 571
« Reply #193 on: July 07, 2014, 09:54:23 AM »
i wouldnt pay more than $200 for any " good" unit- they are all unknown cores.
TQ are usless for resale
if it was an easy install, would be worth the chance, but well...
bad luck.
Re: 571
« Reply #194 on: July 07, 2014, 10:05:25 AM »
Yeah, that's gotta change.
