Author Topic: 571  (Read 222127 times)
Re: 571
« Reply #75 on: May 01, 2014, 02:43:14 PM »
how is the tow rig doing?
Re: 571
« Reply #76 on: May 01, 2014, 02:53:06 PM »
waiting on me i think
Re: 571
« Reply #77 on: May 01, 2014, 03:08:20 PM »
well get going yo!
Re: 571
« Reply #78 on: May 01, 2014, 03:24:06 PM »
Vendors suck!
The car may be done for a Sunday run but both it and the tow rig together seem highly unlikely if I even have parts tomorrow. Spencer's rig is available to hog my trailer to the race though, at least there's that!
GBR's weak abused clutch should be off the hook :)
Re: 571
« Reply #79 on: May 01, 2014, 11:22:10 PM »
Less progress than I'd hoped for tonight – 97% out for Sunday. New coilover installed,  jam nut with good threads solidly welded to link with completely stripped threads.
Dash trimmed but didn't get to column and shifters as hoped. Nowhere near to tires.
Found a plug on an old Cummins harness for the 3 wire temp sensor so I didn't need to buy that. Oh well. eBay it back I guess
Re: 571
« Reply #80 on: May 02, 2014, 08:19:54 AM »
weak!
Re: 571
« Reply #81 on: May 02, 2014, 08:43:43 AM »
No tow rig anyway :-/
Re: 571
« Reply #82 on: May 02, 2014, 08:53:57 AM »
excuses must be your new second part time job!
Re: 571
« Reply #83 on: May 02, 2014, 08:59:28 AM »
Side work has pretty well dried up now that you mention it.
« Reply #84 on: May 04, 2014, 01:21:32 AM »
Can't thank smike enough for help.
Link fixed
Bad bushings in front uppers replaced (owe Matt (2) roughstuff BUSH)
Driveshaft fixed (owe Matt (1) 1350)
Coil straightened
PCM mounted
Orbital moved
Hood trimmed and installed
Shifter mounted
Intake flip fully finished
Bad injector lower o-rings replaced
5 tired dis/mounted
Needs
zip tie check
Passenger harness
Tools and tire strapped down
Full fluids check
Secure tcase shifter pivot
Tin installed
Prefer
Rear brake pads (lookup or pn?)
Paint squirted
Replace switches
Fan controller
Fix lower bolt in front diff
Loctite front diff bolts
Tcase shifter pivots
That's all I can think of for the short list
Re: 571
« Reply #85 on: May 06, 2014, 10:48:07 AM »
Hitting this thing Weds night. Planning on dash coverage around orbital, new switches, front diff locktite and drill/tap bottom hole one size up, couple idiot lights, probably not a fan controller (later...)
Thursday harnesses, paint, tin install.
Re: 571
« Reply #86 on: May 06, 2014, 10:49:01 AM »
sweet highway cleanup wednesday!
« Reply #87 on: May 06, 2014, 10:53:09 AM »
That's been poorly advertised!
I ain't got time to clean a highway, I've got a race! (Drove our stretch last night, it looked like SHIT)
Re: 571
« Reply #88 on: May 06, 2014, 07:24:00 PM »
Shipping notification on belts. Sweet!
Re: 571
« Reply #89 on: May 08, 2014, 12:49:24 PM »
