Re: 571
« Reply #90 on: May 08, 2014, 01:17:29 PM »
http://www.ruffstuffspecialties.com/catalog/14BSRW.html
These are for a 14 Bolt Single Rear Wheel (SRW) housing (73-87) and use '73-'87 3/4 ton, 4x4, Chevy Calipers & Rotors
Re: 571
« Reply #91 on: May 08, 2014, 02:00:57 PM »
Gracias!
Re: 571
« Reply #92 on: May 08, 2014, 02:19:41 PM »
Fuck me! Same goddamn belts I bought from Speedway just arrived. Not reversed.
1/4" Driver will be to the front on a right side ratchet application.
Re: 571
« Reply #93 on: May 08, 2014, 05:15:07 PM »
They'll be making it right. I'll be making it work. And they're okay with making it right free I make It work.
Other news:
Re: 571
« Reply #94 on: May 08, 2014, 09:54:30 PM »
Looks almost normal...
Re: 571
« Reply #95 on: May 09, 2014, 12:12:42 AM »
Ignition and fan switches were both getting flakey. Swapped.
Passenger pads done. Driver caliper seized :(
NSS and rev lights done. New amber done. Front marker lights on ignition. I'm a Christmas tree!
Needs some ties clipped, overflow balloons replaced, fluids checked, fluid and tool storage populated, hi lift mounted.
Re: 571
« Reply #96 on: May 09, 2014, 08:13:09 AM »
good luck!
Re: 571
« Reply #97 on: May 09, 2014, 08:26:31 AM »
Caliper in stock. Running and packing inside stuff. Then caliper.
Re: 571
« Reply #98 on: May 09, 2014, 01:56:27 PM »
Only two hours off target… Finally rolling!
Re: 571
« Reply #99 on: May 10, 2014, 12:17:42 AM »
Suck down broke in transit. Ratchet straps to get out of trailer and repaired. Fluids storage refilled and packed.
6th wheel procured, not mounted.
All seemed very well running across the street to get the wheel. I missed prerunning by ~90m. Smike and matt said there are some surprise puddles and some new trails. Hope it's a good race!
Re: 571
« Reply #100 on: May 10, 2014, 07:15:25 AM »
Good luck! Give em hell
Re: 571
« Reply #101 on: May 10, 2014, 02:39:38 PM »
- oil cooler?
- oil temp gauge?
- idiot lights with good gauges and gauge shield
- relocate radiator?
- bigger trans cooler?
Re: 571
« Reply #102 on: May 26, 2014, 07:55:21 PM »
Power washer makes for a much more thorough cleanup but I don't think it's any faster. Maybe less work and more fun though.
300 out the door for a 6.5hp gasser from HF. On sale, minus 20%. It is every bit as powerful as any coin op self wash I've been to, very pleased with it.
Still not running perfect. I swear I hear another vacuum leak but I can't find it. Starting fluid can't find it. If it is a leak it has to be a gasket or I ring.
Re: 571
« Reply #103 on: May 27, 2014, 09:13:14 AM »
get the pump saver stuff if you want it to last more than a year
Re: 571
« Reply #104 on: May 27, 2014, 10:57:51 AM »
I'm very used to that stuff with paint sprayers with a draw straw and priming output, what's the proper method to get that shit where it needs to be inside a power washer?
