Author Topic: 2003 Ram 2500 CCLB  (Read 143173 times)
Re: New truck for etk
« Reply #345 on: August 30, 2024, 08:51:15 PM »
So, I tried putting my original cruise buttons on with the new wiring harness and it works 100%.
« Reply #346 on: September 06, 2024, 10:50:24 AM »
700 miles covered.  CEL came on as I pulled in my driveway.  Oxy sensor 2 slow response and EVAP.  Both have came and went before.  I have oxy sensors and purge valve in stock.
« Reply #347 on: September 06, 2024, 11:08:58 AM »
* mr.mindless likes this post
« Reply #348 on: September 06, 2024, 03:48:34 PM »
great picture!
« Reply #349 on: September 11, 2024, 06:32:15 PM »
One O2 rounded off.  Had it moving 3/4 of a turn then it rounds off.  >:(
« Reply #350 on: September 12, 2024, 07:31:09 AM »
Gotta be careful on those, the carbon buildup on the threads often makes them a fight all the way out:(
« Reply #351 on: September 12, 2024, 09:11:56 AM »
Should have just cut off and used a reg socket.  I'll try that with the second one.  I used a O2 socket with a hose clamp around.  And heat of course and been hitting it with PB for 5 days.
« Reply #352 on: September 15, 2024, 04:10:26 PM »
Just crawled back under the truck and both O2s came right out no problem.  Weird, must be messing with them last time allowed some penetrating oil to get in there.
« Reply #353 on: October 01, 2024, 08:49:42 AM »
CELs off by themselves.  Returning from Lake Placid I had to do a detour just south of Speculator which is basically one road surrounded by Wilderness Area.  It added almost an hour and dumped us out on 90 in Herkimer.  Cruise, that has been working fine, stopped working completely as soon as we got on ::).
« Reply #354 on: October 07, 2024, 01:17:09 PM »
New clock spring installed, no change, still intermittent.  Cruise came back, I'm assuming, cause battery disconnect/reconnect.  This is the end of the road I guess.  It'll work or it wont...
New truck for etk
« Reply #355 on: October 07, 2024, 01:55:58 PM »
Drove up Whiteface. Checked at the bottom, my brakes weren't any hotter then normal. New F150 in front of me and 1st gen Tundra behind me both brakes smoking lol.
« Reply #356 on: May 02, 2025, 12:06:54 PM »
Retrieved from storage.  It's suffered a rear marker light and windshield washer pump.  Picked up a brush guard on FBM a couple weeks ago.  Heading to Raystown lake, PA next week for MTB festival.
« Reply #357 on: May 05, 2025, 12:15:12 PM »
I want happy with commercially available flares.  Tried making my own with some garden edging.  I think it looks alright, should do the job anyways.  We’ll see how they hold up.
« Reply #358 on: May 16, 2025, 01:45:28 PM »
600 miles to PA and back. Two stops at the Turkey Ranch.
Cruise worked fine on the way there, not at all on the way home. Going in for inspection next week, I'll have them look at it...
Transmission continues to suck. Up a steep hill its 5k rpm, to 3k for 5 seconds, to 2.5k until it looses all momentum, repeat. OD locked out. I have 1,2, D on the stalk with a OD lockout button, so I can't do manual 3rd.  Seems like its missing a gear...
« Reply #359 on: May 16, 2025, 02:06:24 PM »
It is suppose to have a 545RFE. It says 554RFE on the trans (I checked twice). That doesn't exist on the internet. Assuming its a 545RFE
Gear Ratios:
1st 3.00:1
2nd 1.67:1
2nd Prime 1.50:1 (Only used when a kickdown acceleration)
3rd 1.00:1
4th 0.75:1
5th 0.67:1 (545RFE only)
Reverse 3.00:1
