Author Topic: 2003 Ram 2500 CCLB  (Read 143106 times)
Re: New truck for etk
« Reply #315 on: July 21, 2024, 01:44:53 PM »
I see.  I couldn't find the cruise buttons though.  I was able to check both brake switches which one is part of the cruise permission.
« Reply #316 on: July 21, 2024, 01:47:32 PM »
Button / clockspring/ column harness makes the most sense. Glad scanner confirmed. If you can find button actuation that’ll obviously be most helpful.
« Reply #317 on: July 21, 2024, 02:10:42 PM »
Ha! I took the screw out of the back of the cruise buttons. If I give it a good jostling, I can get it to set 1/10 times.
« Reply #318 on: July 21, 2024, 02:17:25 PM »
It does indeed have trans temp.
« Reply #319 on: July 30, 2024, 09:17:15 AM »
The cruise buttons listed to fit this truck are a totally different style.  I got these on eBay as they looked correct, listed for 2002 1500.  They are the right buttons but different wiring.  3 wire vs 2 wire, hardwire vs plug.  Can’t find the right ones ::).
« Last Edit: July 30, 2024, 09:22:43 AM by etk300ex »
« Reply #320 on: July 30, 2024, 09:20:04 AM »
« Reply #321 on: July 30, 2024, 05:17:45 PM »
junkyard time!
« Reply #322 on: July 31, 2024, 10:16:45 AM »
Yeah, I suppose.  This type should be specific to just 2002-2005 1500 or 2003-2005 25/3500.  The one I just bought that was wrong was listed as 2002 1500  ::).
« Reply #323 on: August 02, 2024, 09:09:57 AM »
Took it for a drive.  Lamp Out seems to be happy after twisting pass rear harness.  Did the same with the cruise wiring and now it works about 1/5 times.  O2 sensor and Evap codes have not returned.
Had to do a complete rebuild on my slide out for the fridge.  I forgot to put the lock on it one or three times which allows it to slide out while driving and bent the sliders all up.  I used 100lb sliders which is the largest Lowes has.  I went with self closing this time which gives it a little more resistance to pull out, however, it is too heavy to self close.  I found some 250lb sliders on Amazon I think I'm going to try.
Added a second 100ah battery.
Was bored on a Teams call yesterday and randomly started looking at underbody boxes on Amazon.  Found a Buyers aluminum diamond plate 30x12 scratch-n-dent for $200, normally $333.  Said no cosmetic damage.  Hopefully a score.
Still need to address slightly worn carrier bearing.  I measured it and falls between both options on RockAuto ::).  I need to remeasure I guess.
« Reply #324 on: August 05, 2024, 12:51:27 PM »
 Secured with a self latching gate latch
« Reply #325 on: August 05, 2024, 12:53:55 PM »
Underbody box came in factory box sealed in plastic. Fits perfect. Score!
« Reply #326 on: August 07, 2024, 11:37:59 AM »
The correct cruise controls popped up on ebay this morning, for only a minor raping
« Reply #327 on: August 08, 2024, 08:36:18 AM »
The shaft that goes into my carrier bearing is 1.4135 OD.  Options are 1.378 or 1.575 bearing ID.  Am I measuring it wrong?
« Reply #328 on: August 08, 2024, 08:56:38 AM »
no step thats hidden inside the bearing your missing?
« Reply #329 on: August 08, 2024, 09:06:19 AM »
Not that I can see.  There is a, I'll call it a bearing cover, but it appears to be the same diameter.
