Took it for a drive. Lamp Out seems to be happy after twisting pass rear harness. Did the same with the cruise wiring and now it works about 1/5 times. O2 sensor and Evap codes have not returned.
Had to do a complete rebuild on my slide out for the fridge. I forgot to put the lock on it one or three times which allows it to slide out while driving and bent the sliders all up. I used 100lb sliders which is the largest Lowes has. I went with self closing this time which gives it a little more resistance to pull out, however, it is too heavy to self close. I found some 250lb sliders on Amazon I think I'm going to try.
Added a second 100ah battery.
Was bored on a Teams call yesterday and randomly started looking at underbody boxes on Amazon. Found a Buyers aluminum diamond plate 30x12 scratch-n-dent for $200, normally $333. Said no cosmetic damage. Hopefully a score.
Still need to address slightly worn carrier bearing. I measured it and falls between both options on RockAuto
. I need to remeasure I guess.
