Author Topic: 2003 Ram 2500 CCLB  (Read 132370 times)
Re: New truck for etk
« Reply #285 on: May 31, 2024, 01:53:08 PM »
I'm sure fresh fluid doesn't hurt. But quite a pleasant surprise as good as the old stuff looked and smelled. I'd have bet pretty hard on no change.
« Reply #286 on: May 31, 2024, 02:16:41 PM »
Likely placebo effect ;D
« Reply #287 on: July 01, 2024, 09:06:47 AM »
Smike, Dodge Ram 3rd gen 8 foot long box fits 03 through 09 2500/3500 and 02 through 08 1500
« Reply #288 on: July 03, 2024, 09:16:50 AM »
Tank I would like mounted
« Last Edit: July 03, 2024, 10:36:44 AM by etk300ex »
« Reply #289 on: July 03, 2024, 05:05:04 PM »
What is said tank for?
« Reply #290 on: July 03, 2024, 05:06:35 PM »
water.
its AL?
looks painted steel no?
« Reply #291 on: July 03, 2024, 05:53:04 PM »
I would guess little air tank to fill mountain bike tires?
« Reply #292 on: July 07, 2024, 08:21:14 PM »
Steel tank.  Water for camping, washing hands feet and whatnot.
« Reply #293 on: July 07, 2024, 08:58:24 PM »
Annual trip to PA was a bit of a rough weekend for the old Ram.
CEL 5 minutes down the road. Turned around, was P0441 Evaporative Emission System Incorrect Purge Flow. Took out the Purge Valve and blew it out with the air compressor and it went away. Bought one at AutoZone on the way but never installed.
Cruise completely inop. Its always been a bit temperamental, but would always work.  This vehicle is particularly hard to keep at a constant speed with the accelerator lol.
Lamp Out dinger went off the rails. Constant dinging for a couple miles until I pulled over and removed a taillight so it would just stay on.  (Stock taillights are mounted under flatbed to fix Lamp Out and fast blinkers).  Just ordered two taillight circuit boards. This is a common problem. This used to go off every once and a while but not enough to care.
Caught a stone between the rear rotor and the shield which made this crazy loud screeching noise. Took a few minutes to figure out what it was.  It was a PITA to remove, I didn't have any tools that would fit in there. Ended up using a butter knife, vice grips, and a hammer haha.
Sun visor hanger shattered when I went to hang the visor for no reason at all, odd.
CEL back on 10 minutes from home. P0139 O2 sensor circuit slow response Bank 1 Sensor 2.  Will pull tomorrow and see what's up with that...
Just hit 167k. Heading to the Adirondacks Thursday.
« Reply #294 on: July 07, 2024, 09:00:16 PM »
i think matt listened to that lamp out dinger for like 3 years
i was ready to punch to dash out after 10 minutes of riding with him
« Reply #295 on: July 07, 2024, 10:05:12 PM »
Lol. I thought I looked ar the tail light circuit boards when I first bought the truck and they were very expensive. They are $12 so not sure what happened there.
« Reply #296 on: July 08, 2024, 10:31:28 AM »
is steel tank going to work?  or just turn to rust goo after a few months?
« Reply #297 on: July 08, 2024, 11:54:51 AM »
wonder if we should have pulled that loose sensor all the way out to see what it looked like before jamming it back in the trans
I suddenly remember that I think I did several years in my Ram with no cruise. I wonder if I look back through the thread here if I say what fixed it. I recall regret of not doing it sooner since it was easy.
« Reply #298 on: July 08, 2024, 11:56:08 AM »
looks like it was a bad front wheel speed sensor
Need to do sway bar links.
Maybe shocks?
Rattle 90% gone. Steering super nice. 110 miles of functional cruise control and counting. Not too far from doubling miles driven with cruise under my ownership. Hopefully LF speed sensor routing is now safe... third try a charm.
Put 1/8 turn on most oil pan bolts. See if that dries up a wet side of the pan.
« Reply #299 on: July 08, 2024, 12:54:16 PM »
I think if its used for the weekend and drained it will be fine for several years.
