Author Topic: 571  (Read 264707 times)
Re: 571
« Reply #975 on: March 11, 2018, 10:17:19 AM »
Summit has mandrel bent exhaust tube at decent prices.
Re: 571
« Reply #976 on: March 14, 2018, 11:59:59 PM »
Mike, what’s the shopping list for that cam that was suggested? Need to think about that.
Re: 571
« Reply #977 on: March 15, 2018, 11:44:07 AM »
forwarded stuff on FB messenger
cam
pac springs
WIdeban 02 needed for tune
Re: 571
« Reply #978 on: March 15, 2018, 11:46:11 AM »
also confirming same for 6.0, i had asked for 5.3
Re: 571
« Reply #979 on: March 15, 2018, 11:48:57 AM »
Wideband needs a separate O2 to the one per bank for the computer?
John can do tune?
You going to do this or just run the cheap motor? I plan to check compression and go from there. If compression is good I think I’ll get Pete on the way. Why not add a week of extra work when it’s less than a month to the race?
Re: 571
« Reply #980 on: March 15, 2018, 11:57:36 AM »
John said if the engine is in his shop upsidown on an engine stand, he can do the cam and springs in 40 minutes.  wideban and a place to run some pulls (open parking lot) he can tune.
same parts for 5.3 or 6.0 junkyard build
Re: 571
« Reply #981 on: March 15, 2018, 12:28:12 PM »
Sounds good. You have or know of a stand? I don’t.
Re: 571
« Reply #982 on: March 15, 2018, 03:12:40 PM »
I have engine stand you can borrow.
Re: 571
« Reply #983 on: March 15, 2018, 04:03:46 PM »
thanks! I'll keep you posted...
Re: 571
« Reply #984 on: March 15, 2018, 05:13:19 PM »
i own two, both in use haha
Re: 571
« Reply #985 on: March 15, 2018, 11:07:16 PM »
Time to get a crane and collect my missing tools from Joe.
Motor mounts, headers, trans shifter, tv cable, cooler lines.
And whatever I’ve forgotten.
Needs some vacuuming.
Motivation to find room for better air filtration
Re: 571
« Reply #986 on: March 15, 2018, 11:12:17 PM »
Any suggestions on easy and effective methods to clean out that throttle body and intake or should I just spray a ton of carb and brake cleaner through it all? New motor is drive by wire so I plan to run this intake.
Re: 571
« Reply #987 on: March 16, 2018, 02:11:10 AM »
There are some mil surplus Donaldson items on eBay. Good deals to be had. I’ll be finding a new home for the battery and hoping for a codriver with small feet should I ever find one. Hopefully make this motor last a bit longer with reduced silica intake.
Just need to grab some appropriate elbows and a straight flex once the filter is mounted.
Re: 571
« Reply #988 on: March 16, 2018, 06:49:40 AM »
intakes are same, just need to add a few of the brass inserts which can be done with a propane torch
Re: 571
« Reply #989 on: March 16, 2018, 06:51:30 AM »
the newer intake will also have the EGR deleted instead of yours plated i believe
