Author Topic: 571  (Read 264702 times)
Re: 571
« Reply #945 on: January 22, 2018, 09:54:53 PM »
hmm.
i have only killed 1 ls alternator.  cheepies.
Matt runs the higher amp one, i dont.
Re: 571
« Reply #946 on: January 23, 2018, 12:27:29 AM »
I run the large case I think 130a
it gives me voltage after some run time and high revs, but not before. spraying things in it made no difference.
it is getting voltage from the ECU. makes no difference to tickle direct to the single pin. do have good continuity on charge wire through shutoff.
This alt was installed in July give or take. I changed one last year too. And right before Hammers, I have that one in a box marked "squeaks" somewhere as a trail spare.  Either the alt or the (also months-old) power steering pump is squeaking now too. I guess I'll find out when I change it.
humbug. Lost hours to diag because I couldn't believe it, but at least it's only 15-20m to change it.
Re: 571
« Reply #947 on: January 23, 2018, 12:45:47 AM »
14-July 2017. lifetime warranty. carquest reman from advance. $136 well-spent dollars. Last minute, without a doubt.
Re: 571
« Reply #948 on: January 23, 2018, 02:01:35 PM »
"limited lifetime warranty" means I have 90 days from today of exchange remaining. Not even the remainder of a 1 year from initial purchase.
awesome.
Or so they say in-store, anyway.
Re: 571
« Reply #949 on: January 23, 2018, 02:05:16 PM »
i guess it evens out
Quote
Replacement parts are warranted for 90 days from the date of exchange or the remainder of the warranty period on the original part, whichever is longer.
What is Not Covered
Parts installed on vehicles used off-road or for racing purposes.
Re: 571
« Reply #950 on: January 23, 2018, 02:28:14 PM »
umm hello...
Re: 571
« Reply #951 on: January 23, 2018, 03:28:03 PM »
yeah I know. Last Minute happens. I don't have keys yet and they're open much later :-
Re: 571
« Reply #952 on: January 23, 2018, 11:01:15 PM »
Ok, problem persists. Any foggy clues? Tickle wire was showing something like 9.5v when battery was at 10.5 last night. New alt doesn’t show 13.7 as soon as I start the car. That’s as far as I got on that. Baffled.
Didn’t open the big door to rev it up and see if it starts producing after som R’s and minutes. Haven’t load tested it. But it sits at 12.0 at idle and at 1500. Digital gauge dvm verified.
I’ll load test it tomorrow I guess. See if I need to dig further or if the ecm just prefers 12 to 13.7.
Re: 571
« Reply #953 on: January 24, 2018, 10:06:58 AM »
Re: 571
« Reply #954 on: January 24, 2018, 12:25:22 PM »
not sure if this what you have,  might be close
this is a link i have used,  i'm surprised its still active...
6 Pages    page 6 has the bench test
https://alternatorparts.com/cs130-sbpage1.html
« Last Edit: January 24, 2018, 12:29:10 PM by gif »
Re: 571
« Reply #955 on: January 24, 2018, 12:38:45 PM »
might be interesting to test with an idiot light, didn't know there were parallel paths to energize.
Re: 571
« Reply #956 on: January 24, 2018, 10:51:38 PM »
Chased good grounds all over.
Bad shutoff switch. Secondary charge circuit is intermittent. F me! Would never have found it if it hadn’t made itself worse. I tested continuity on that circuit and measured actual ohms and it was good Monday.
At least it’s found. If only I’d not burned up the last new shutoff switch.
« Reply #957 on: January 26, 2018, 02:19:44 PM »
Second try worse than the first. Patch leaked same as first attempt but filler popped this time. Tire is junk, another  tube unit.
Re: 571
« Reply #958 on: January 26, 2018, 02:20:58 PM »
Correction: third try. I peeled out the second try before even testing. Had a giant internal bubble.
Re: 571
« Reply #959 on: February 15, 2018, 04:01:31 PM »
Engine swap or rebuild?
Cam, heads, bearings, rings and a dingleball hone? Seems like too much of a shortcut if putting money into it. Probably deserves .020 over and pistons. LS like to slap but it is an iron block. That’s 1500-2000 in parts and machining isn’t it?
Rebuild 4 bumpstops
Make it have 2 O2 sensors
Check injectors
Driveshafts
Rear link redo just like the front from last year
Freshen trans and fix spare trans. Behaves perfectly (would like to add compression braking in all gears) except for a leak leading to low fluid after sitting.
2 more 37” Toyos due to cost vs. replacing all with another tire
