Author Topic: matts buggy build  (Read 225104 times)
Re: matts buggy build
« Reply #765 on: January 31, 2017, 01:19:25 AM »
99.95% ready to pull motor.
fresh 6.0 sitting on hoist next to it.
« Reply #766 on: January 31, 2017, 10:01:50 AM »
FUEL SYSTEM INFORMATION
1999-2003 4.8, 5.3, 6.0 all had a fuel rail with 3/8" supply line and a 5/16" return line.  The fuel pressure regulator is on the fuel rail, and has a vacuum line to the intake manifold. In 2004, truck engines went to a single 3/8" supply line, with NO RETURN LINE (returnless) except 5.3L L59 Flex Fuel vehicles.  For 2004, Flex fuel engines KEPT the return line, BUT used a fuel pressure regulator with a lower pressure ratting.  2005 5.3L L59 Flex Fuel engines switched to a single 3/8" supply with NO RETURN line in 2005.  Non flex fuel engines, fuel pressure spec is 55 to 62 psi with vacuum line disconnected, fuel pump running.  5.3L Flex Fuel engine 2001-2004, 48-54 psi with vacuum line disconnected, fuel pump running. 2005+ with returnless fuel rail all shared same fuel pressure spec, 55-62 psi.  There is no vacuum reference on these, so fuel pressure should remain constant under all operating conditions.  The computer is programmed differently for fuel flow rate depending on type of fuel rail.[/b]  This is important to know when having a PCM programmed.  (exception: 04 express van and 04 trailblazer/envoy still used return style fuel rail, 05+ single line, retunless rail)
« Reply #767 on: February 04, 2017, 11:10:36 PM »
all link heims changed
motor mount bushings changed
new aluminum tie rods made and installed
new tie rod hiems
205 fuse mid joint changed
rear shaft pulled and straightened
205 fluid level sight glass added and fluid changed
air filter serviced
steering filter serviced
6.0 motor dressed with 99 fuel rail, 99 Throttle body, 99 oil pressure sensor, new PS pump, new Alternator
2 broken exhaust bolts extracted
flywheel changed
5lb rear fire ext mounted
probably 10 more PITA things done and complete.
should have trans back tomorrow for motor install and braded cooler line mock ups
solid week of work on this unit- after 3 years of racing everything looks pretty good so far
« Reply #768 on: February 06, 2017, 03:02:37 PM »
Trans builder says looks like the TH400 from 928 looks like the day he put it in- no issues.
buttoned up and waiting on a filter for tonight
« Reply #769 on: February 06, 2017, 04:07:42 PM »
that's impressive.
« Reply #770 on: February 07, 2017, 01:43:05 PM »
Matt found some severe rear axle truss cracking on the top right side upper link at axle.  Further investigation mandated using the porta ban to remove and rebuild.  the truss isnt trying to rip it self off the axle, but rather the top plate of the 1/4x2x3 box is trying to shear it self in to pieces from the push pull loads from the upper links.  plug welded 3/8" plate top plate with brackets put back on with additional braces is the plan.
« Reply #771 on: February 09, 2017, 01:28:18 AM »
50psi of oil cold idle.  new 6.0 sounds rowdy   8)
couple loose ends and cosmetics, 928 is in great shape.
« Reply #772 on: February 10, 2017, 09:32:06 AM »
front chassis work with removable crossbar and cooler mount finished up last night.
new trans fittings coming in today to resolve drive shaft clearance issues so it should be able to be ripped around the shop lot Saturday.
coolant leak at water neck needs addressing.  tire carrier work / tins
« Reply #773 on: February 10, 2017, 09:56:56 AM »
nice work, gents
« Reply #774 on: May 31, 2017, 04:03:55 PM »
Thinking of switching to these when my current set of Trepadors are done. First need to see if I'm even worthy to get them haha.
http://www.bfgoodrichracing.com/desert-racing-bfgoodrich-baja-ta-kr3-40x12-5r17/
« Reply #775 on: May 31, 2017, 05:54:56 PM »
The KR's are not the right tire for us for anything we do.  the Mint maybe but thats all.
« Reply #776 on: June 01, 2017, 09:03:07 AM »
KR3's look just like Nittos and Toyos not talking about KR's.
« Reply #777 on: June 01, 2017, 11:22:07 AM »
they remind me off the european offroad tires that I've always liked so much with the open shoulders and closer traction pattern in the middle.
« Reply #778 on: June 09, 2017, 01:46:29 AM »
got two nights on the lift.
two tires repaired.
some other things.
« Reply #779 on: June 11, 2017, 09:27:03 PM »
looks like prep paid off.
Matt i think got 2nd in class and 2nd over all.
