Author Topic: matts buggy build  (Read 225356 times)
Re: matts buggy build
« Reply #750 on: September 25, 2016, 09:59:21 PM »
forgot to yell at you for no limit strap!
order some already!
« Reply #751 on: December 20, 2016, 09:10:26 AM »
« Last Edit: December 20, 2016, 09:17:37 AM by GBR928 »
« Reply #752 on: January 11, 2017, 11:40:53 AM »
If excessive oil is present in the PCV hose, replace the PCV valve (Type 948C) (2) with a new-style fixed orifice PCV valve, GM P/N 12572717(1).
something to investigate
« Reply #754 on: January 11, 2017, 01:37:44 PM »
that's very interesting. Have to check my PCV... I don't think I'd be fouling one and only one plug if that were my issue though.
« Reply #755 on: January 11, 2017, 03:59:12 PM »
in the shop and a lot of discussion this week on motor and what to do.
« Reply #756 on: January 12, 2017, 07:59:15 PM »
« Reply #757 on: January 13, 2017, 07:31:54 AM »
That looks suspiciously like the one i was talking about. Lol
« Reply #758 on: January 13, 2017, 08:50:41 AM »
sure does. no 710 cap and right neighborhood
« Reply #759 on: January 13, 2017, 01:03:41 PM »
It is the same one...
« Reply #760 on: January 14, 2017, 09:24:27 PM »
artec arms and 3/4 ton front brake swap done.
fresh front gear set and RCVs packed.
rear gear set inspected.
front drive shaft pulled for rebuild.
« Last Edit: January 19, 2017, 05:01:49 PM by GBR928 »
« Reply #762 on: January 19, 2017, 05:25:04 PM »
Braided hose options for transmission cooler
Not sure if I should get synthetic rubber:
https://www.summitracing.com/parts/rus-632090
or PTFE lined:
https://www.summitracing.com/parts/sum-220985
Sweet TH400 1/4" thread to -6 AN adapters:
https://www.summitracing.com/parts/rus-640520
~$160 to upgrade to stainless steel braided hose!
« Reply #763 on: January 19, 2017, 06:13:42 PM »
PTFE
« Reply #764 on: January 19, 2017, 06:28:40 PM »
