Author Topic: matts buggy build  (Read 225133 times)
Re: matts buggy build
« Reply #735 on: December 31, 2015, 06:04:18 PM »
Changed the rear lower links?
« Reply #736 on: January 01, 2016, 12:08:00 AM »
yes, along with all suspension mounts and 5" out of the hood line
« Reply #737 on: April 19, 2016, 09:19:20 AM »
https://www.grainger.com/product/TRITAN-Flange-Bearing-36UY36?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/36UX90_AS01?$smthumb$
This will be here tomorrow, hopefully we can improve the design on th efront shaft and smash it with some rocks at Big Dogs! Will have two ebay spares as well if needed.  8)
Need to dust this car off!
« Reply #739 on: April 27, 2016, 08:08:22 AM »
Haha those bushings will wear soooo fast in front!
« Reply #740 on: April 27, 2016, 08:54:35 AM »
In dans defense - you had hiems on both ends? Below centerline + bushing should be better off.
I only chew through upper bushings (front and rear both), lowers do okay.
« Reply #741 on: April 27, 2016, 08:59:08 AM »
below centerline = broken shock shafts when easy coast rock crawling.  id give that link a weekend at RC before something around it fails.  Im sure the actual link and fabrication is pretty HD and normal ruff stuff quality, but some design and application issues we have proven over and over many times.
has to be even worse than heim / heim and a wobble stopper.
« Reply #742 on: June 02, 2016, 09:29:23 AM »
siren installed, spare tire carrier fixed, broken king pin bushing changed, grease job, tire swap and check completed last night.
« Reply #743 on: July 25, 2016, 12:15:49 AM »
another 60 gear set bites the dust.  lots of chips out of the pinion.  new set 95% in.  need to grab another carrier bearing or the right puller.  bah.
rcvs clicking
both king pin bushings changed and a preload washer added.
« Reply #744 on: August 16, 2016, 10:11:08 AM »
Want to add the following over TLO week 9/5-9/9 before the Line Mountain 7 Miler (currently sitting 6th in series points out of 200 drivers and have never finished this race officially):
Artec Arms
Bronze 60 Bushings
3/4 ton brakes from Lugnut 4x4
NEW FARM JACK
Replace Loose Heims in Front
Need to start planning and prepping for Mint 400 and KOH pit support/pre-running!
« Last Edit: August 16, 2016, 10:14:44 AM by rockaholic »
« Reply #745 on: September 20, 2016, 01:33:01 PM »
13 straight endurance races without any flat tires on this guy! 8)
carchameleon
« Reply #746 on: September 20, 2016, 04:02:54 PM »
famous last words...  :P
« Reply #747 on: September 20, 2016, 04:17:03 PM »
im sure the mint will make up for it haha
« Reply #748 on: September 21, 2016, 07:27:12 AM »
ill bet on this ;D
« Reply #749 on: September 21, 2016, 09:55:32 AM »
Or the 7 Miler this past weekend!
