Author Topic: matts buggy build  (Read 225342 times)
Re: matts buggy build
« Reply #705 on: September 08, 2015, 10:39:11 AM »
Somebody else broke a power steering pump shaft. nothing good in the thread yet, but maybe later?
http://www.pirate4x4.com/forum/general-4x4-discussion/2149522-power-steering-pump-issues-full-hydro.html
« Reply #706 on: September 14, 2015, 09:45:52 AM »
matts broken shafts were from incorrect orbital
http://www.summitracing.com/parts/rfl-8001
« Reply #707 on: September 15, 2015, 11:47:02 AM »
broken passenger stub took out spindle driving it out.
stub, spindle, spindle bearing and seals changed out last night.
« Reply #708 on: September 15, 2015, 12:22:10 PM »
pic of the stub break?
« Reply #709 on: October 02, 2015, 09:22:44 AM »
Updated KOH 2016 List
-Engine management
-Skid plate repair
-spacers in bumps
-Winch replacement
-Fox shocks
-new hood
-lower hood line
-high/low range shifter
-aluminum firewall and trans tunnel
-paint chassis
-rebuild front axle shafts
-make spare driveshafts
-replace all loose heims
-straight rear links
-amber light in
-change all fluids
-bigger radiator/fan
-Move GPS to co-driver side
-co-driver handle bars
-Re wire GPS external antenna
-New battery, spare on board battery
-Tool bag rack in back over fuel cell
-Frayed hydro line replaced
Parts to order:
Driveshafts
2 Tires
2 Wheels
Airfilter
Outerwear
Hydroline
Alternator
Starter
Power Steering Pump
Battery
Front Axle Shafts and Super Joints
Rear Axle Shafts
Front 60 Spindle
2.0 Springs
Heims
2" OD 1.25" thread bungs
GPS Antenna
Front Light Bar
« Last Edit: November 10, 2015, 10:59:54 AM by rockaholic »
« Reply #710 on: October 09, 2015, 02:12:04 PM »
20lb shop fire ext and how fast i can run with it tested last night      :o
« Reply #711 on: October 09, 2015, 02:26:51 PM »
more back story and pictures required.
« Reply #712 on: October 09, 2015, 02:53:39 PM »
ruh roh.
« Reply #713 on: October 09, 2015, 02:58:37 PM »
it was bad.  worst so far.  Details probably better over beers sometime.
« Reply #714 on: October 09, 2015, 04:00:57 PM »
things mostly OK?
« Reply #715 on: October 09, 2015, 04:13:13 PM »
Things are okay. Sacrificed a helmet, flannel shirt, outerwear, and a few melted zipties and wire casings.
« Reply #716 on: October 12, 2015, 10:07:50 AM »
a second night of "i cant believe what just happened"
We couldn't get it started in the trailer again, so it got drug out and pushed into the shop with the shovel.
couple hours later, found some melted wires grounding out the ecm causing no spark through the oil idiot light.
fired and locked again.  pulled #8 and continued fuel poured out.  determined stuck open injector electrically, then pulled and mechanically verified.
someone at work suggested changing the oil if a known fuel flooding situation occurred.  pulled oil drain.  watched 2 gallons+ of fuel spray out.  holy shit
swapped in another injector, ran a few minutes with an oil change, drained and changed oil again.
Ran like a rapped ape again on 8 cyc, broke another 4130 stub at wrangler ave.
« Reply #717 on: October 12, 2015, 10:10:30 AM »
That thing has been on 7 for a long time. Kinda crazy that it just went to flooding status. Very lucky, up glad there wasn’t. More damage via fireball or cyl wall and bearing washing
« Reply #718 on: October 12, 2015, 10:14:48 AM »
took a while to relearn and a couple restarts to get that bank running.  it must have been leaning the shit out of 2,4,6 to try and make up for 8 just dumping fuel.  its had to have been like that for a while.
« Reply #719 on: October 12, 2015, 10:17:42 AM »
For sure. No good for any of the 4
I wonder what my ecu does with only 1 o2. Default map on one bank or run both off the one?
Probably not doing it any favors either way.
