Author Topic: matts buggy build  (Read 225333 times)
Re: matts buggy build
« Reply #690 on: August 18, 2015, 10:04:43 PM »
id bet you be closer to matt- mine gets way better air than either of the low radiator cars.  My car is rated for 20 more HP though.
« Reply #691 on: August 18, 2015, 11:12:37 PM »
Matt’s has heat trouble in woods racing though, doesn’t it?
« Reply #692 on: August 19, 2015, 11:08:19 AM »
Yes only race I stayed below 220 at badlands. Fast woods racing it gets up to 240 still.
« Reply #693 on: August 19, 2015, 12:50:28 PM »
I don't think I have seen 220 at LM. Only time I've seen the temp light is when my fan failed and I think I have that set at 230. I'm usually down around 210, I think.
It's the reason I haven't put a tstat back in. I don't want to screw up my cooling by remedying the tempermenant fix I made!
« Reply #694 on: August 24, 2015, 10:11:07 AM »
I'm not running a tstat either. Airflow isn't the issue either since a seat was pulled in KY and the car still overheated right after the main. Looking at more CBR stuff today.
« Reply #695 on: August 24, 2015, 10:21:54 AM »
did you put a flow restrictor in?
« Reply #696 on: August 24, 2015, 11:02:23 AM »
No, just hollowed out the existing tstat.
« Reply #697 on: August 24, 2015, 11:26:20 AM »
I bet you are moving the water too fast.
I made some parts from my 'stat into a restrictor plate.
« Reply #698 on: August 24, 2015, 11:28:22 AM »
moving too fast= complete BS
« Reply #699 on: August 24, 2015, 01:27:42 PM »
yes.     why does this myth continue to live on? :o
would you ever say that you are moving the AIR to fast?
A common misconception is that if coolant flows too quickly through the system, that it will not have time to cool properly. However the cooling system is a closed loop, so if you are keeping the coolant in the radiator longer to allow it to cool, you are also allowing it to stay in the engine longer, which increases coolant temperatures.
« Last Edit: August 24, 2015, 01:33:42 PM by gif »
« Reply #700 on: August 24, 2015, 01:39:59 PM »
i have no idea why that myth lives on
« Reply #701 on: August 24, 2015, 01:43:02 PM »
engine puts BTU in the coolant, radiator takes the BTU out.   the faster i can get the coolant around the loop the better, IF the radiator is sized properly for BTU removal in the first place.
When I was at GM i had a thermal test bench that we used to test the Fuel Cell coolant pumps.    I had years of data that said "higher coolant flow = better cooling.
« Reply #702 on: August 24, 2015, 02:20:48 PM »
I will try to remember that, data does not lie...
« Reply #703 on: August 25, 2015, 01:56:23 PM »
« Reply #704 on: August 28, 2015, 11:46:33 AM »
found pin hole in trans line leaking
found front right king pin loose and miles from beating threads beyond use.... wasnt welded like it should have been- will be on next tear down.
