Author Topic: matts buggy build  (Read 225190 times)
Re: matts buggy build
« Reply #660 on: May 22, 2015, 09:45:52 AM »
lots o work done last night on this
CBR cooler installed
fox bumps in
skid and exhaust pulled, repaired, wrapped.
Spal fans on CBR cooler are ear piercing screeching loud.... hope they wear in a little and settle down.  right behind occupants helmets.  looks bad ass and should keep cucumber cool now.
« Reply #661 on: May 22, 2015, 10:00:42 AM »
Trans is gonna be cooler than the motor! Better rad fans or airflow mods in the works?
« Reply #662 on: May 22, 2015, 10:02:51 AM »
Airflow mods in the works as well as some better shielding from mud splash. Cores were full of mud yet again from last race. Exhaust wrap around oil pan should lessen engine oil temps as well.
« Reply #663 on: May 22, 2015, 10:17:53 AM »
If it's getting mud packed that's for certain the issue. That's the only time I've had temp issues, really.  Mud flap hanging down off the rear of the chassis in front of it? Or do you think it's from the rear tires?
« Reply #664 on: May 22, 2015, 10:34:10 AM »
Coming in from sides, there's already a flap below
« Reply #665 on: May 27, 2015, 09:44:58 AM »
Coal Bucket Prep = 1 week!!
R&P
Fix broken drive flange bolt
Clean mud from radiator cores
Complete radiator fan tunnel
Bleed coolant system
Cut rear firewall out
Bump pressure check
Dual rates moved down
Rear number board
Fix horn
investigate axle hitting PS pump bracket
Rear bumper (meh)
« Last Edit: May 28, 2015, 09:21:06 AM by rockaholic »
« Reply #666 on: June 03, 2015, 09:56:51 AM »
Gutted and on the lift
ate inner oil slinger, inner pinnion bearing, and ring gear.
« Reply #667 on: June 04, 2015, 12:45:42 AM »
new gears loaded tonight
lubed and bolt checked
horn fuse increased
some radiator shield and inlet mods and good to go for sat race.
« Reply #668 on: June 04, 2015, 07:08:47 AM »
Git er done
« Reply #669 on: June 04, 2015, 08:13:41 AM »
what did you guys do about the cooler fans?a add some gap to increase available air?
« Reply #670 on: June 04, 2015, 11:14:43 AM »
Cooler fans work, that's good enough lol
« Reply #671 on: June 04, 2015, 11:15:49 AM »
The whistling does seem to be more quiet now though after running them for a bit.
« Reply #672 on: June 11, 2015, 09:32:02 AM »
Have a bit of work to get done!
2015 Badlands:
New throttle cable
Intake in cab
Replace loose heims 1.25"
Skid fix
Frayed steering line
New female end on window net bar
Driver side PTT wire fix
Radiator relocate
Shroud radiator
Switch fan blade out with new
Phase front axle shafts
Check:
Shock pressures
Bump pressures
Fluids
Grease everything
Tire pressure
Lug nuts
King pin bolts
Brake slider bolts in rear
Top off fuel
New stuff needed:
Bigger Air filter
Bigger Outerwear
Plumbing for intake
Neck restraints
Spares needed:
Volvo fan relays
Power steering pump OEM
Make a tote of spare parts
« Reply #673 on: June 17, 2015, 03:08:04 PM »
2015 Badlands:
New throttle cable
Intake in cab
Skid fix
Radiator relocate
Shroud radiator
Check:
Shock pressures
Bump pressures
Fluids
Grease everything
Tire pressure
Lug nuts
King pin bolts
Top off fuel
New stuff needed:
Bigger Air filter
Bigger Outerwear
Plumbing for intake
Neck restraints
Spares needed:
Volvo fan relays
« Reply #674 on: July 09, 2015, 10:31:51 AM »
Badlands chewed up another 60 gear set in this guy
awesome!
