Author Topic: matts buggy build  (Read 225357 times)
SlvrJK
  • Full Member
Re: matts buggy build
« Reply #675 on: July 13, 2015, 08:17:49 PM »
no good
« Reply #676 on: July 13, 2015, 11:19:56 PM »
gutted and prepped for first new gear install.  should be wrapped up tomorrow
« Reply #677 on: July 14, 2015, 06:41:12 AM »
Free replacement volvo fan assy from Erie Vo Vo! No questions asked lifetime warranty on used parts!
« Reply #678 on: July 29, 2015, 03:00:08 PM »
the info we were working with last night.
need to check pin 58 is correct wire we were using.
need to verify reader works with plug in to jetta or Ram
Torque app was saying connected to reader, no errors in reader, but unable to connect to ECM.
We have gotten my reader to work on Matts car before, so not sure why we wasted 2 hours last night failing at it.
Truck 1999 5.3L Connector C1 BLUE
Pin 58   DK GRN   1049   Serial Data to OBD2 Port
« Reply #679 on: July 29, 2015, 03:08:00 PM »
« Reply #680 on: July 29, 2015, 03:10:13 PM »
C100 - Inline Harness Connector End View
Pin H   DK GRN   1049   Serial Data Signal (Class 2) - OBD2 Port Pin 2
« Reply #681 on: August 05, 2015, 11:45:26 AM »
Buggy is now OBD2 diagnostic compatible thanks to Delphi spare parts bin.
Need to see if there are some AC Delco AFS105 O2 sensors I can put on for next race rather than the cheapies I bought in KY (can use as spares)
We are KOH 2016 Qualified!
Have some work to do to be able to finish the hardest race in the world (I'm sure I'll be adding much more to this list!):
-Skid plate rework
-spacers in bumps
-Winch replacement
-Fox bypass rear shocks
-lower hood line
-high/low range shifter
-aluminum firewall and trans tunnel
-paint chassis
-rebuild front axle shafts
-make spare driveshafts
-replace all loose heims
-amber light in
-louder horn
-change all fluids
-fix water temp gauge
-bigger radiator/fan
-Move GPS to co-driver side
-co-driver handle bars
-Re wire GPS external antenna
-More lighting, Phantom Sun series from Ryan?!
-New battery and spare on board battery
-Tool bag rack in back over fuel cell
-Frayed hydro line replaced
Spare parts to order:
Driveshafts
Shock
Tires
Wheels
Airfilter
Hydroline
« Last Edit: September 02, 2015, 11:17:44 AM by rockaholic »
« Reply #682 on: August 06, 2015, 02:08:30 PM »
7 in stock
« Reply #683 on: August 18, 2015, 03:01:58 PM »
i wana see a radiator in this thing for line mt
less woman drama more racecar!
« Reply #684 on: August 18, 2015, 05:11:49 PM »
Have you figured out the misfiring issue yet?
« Reply #685 on: August 18, 2015, 05:24:17 PM »
was another bad O2-  we wired it for a code reader now so its easy to look at realtime info on my phone
also had massive exhaust leak pre O2 that wasnt helping.  I believe ran fine at KY other than over heating and puking motor twice before we pulled co seat and cut out mud sheilding
« Reply #686 on: August 18, 2015, 05:26:45 PM »
Get that rad cleaned out fully, too. Looked really dirty in those pictures, mud pack doesn't help cooling....
« Reply #687 on: August 18, 2015, 05:30:34 PM »
Buying new big boy radiator!
« Reply #688 on: August 18, 2015, 06:23:54 PM »
hours were spent straightening radiator fins and making sure clean.  no mud at KY, that wasnt the problem.
the radiators are just too small for 100% duty short course or all out sustained desert running with ambient near 90F
even my car was running 230 after 6 laps in KY.  Full angry foot on floor 95% of course
« Reply #689 on: August 18, 2015, 06:31:39 PM »
10-4
very curious what mine would do. I expect similar to yours (230-240) since both seem to run relatively cool in the woods races.
