Author Topic: Time for Tons  (Read 126215 times)
Re: Time for Tons
« Reply #120 on: April 15, 2013, 09:41:54 PM »
loco CJ has a front D60 welded with NO hydro.    We just bumped up the power steering pump pressure.    He used to drive it on the road.
Re: Time for Tons
« Reply #121 on: April 15, 2013, 10:00:41 PM »
Seems like you have time to order the new locker and get it put in...  ???
Time for Tons
« Reply #122 on: April 15, 2013, 10:20:20 PM »
Thanks Gif, good info. A friend made the same suggestion about boosting the power steering pressure. I think that's what I'm going to do.
Mark... I do have time but this and DB3 have been rather financially abusive in the last few weeks and I still need to get to VA and back! That $350-400 would be coming out of my oh shit fund. I'd rather just weld it for now if it will work.
Re: Time for Tons
« Reply #123 on: April 16, 2013, 07:14:21 AM »
there is no more permanent solution than a temporary fix
 ;D
Re: Time for Tons
« Reply #124 on: April 16, 2013, 08:26:01 AM »
you have an aston martin?
Time for Tons
« Reply #125 on: April 16, 2013, 08:46:37 AM »
Wrong crowd
Dump bus 3
They can be almost as expensive as an Aston though!
Re: Time for Tons
« Reply #126 on: April 16, 2013, 09:47:41 AM »
I'd still rather have a DB than an Aston!!!
Time for Tons
« Reply #127 on: April 17, 2013, 08:13:34 PM »
Spooled front done. Get some more lift/bumpstop in the rear and the rest is cake.
As far as boosting steering power steering, I read that drilling out the orifice sends more volume, shimming puts more pressure on the relief valve spring and increases pressure. Seems that I'd be looking for pressure more than volume?
Time for Tons
« Reply #128 on: April 17, 2013, 10:06:49 PM »
http://comancheclub.com/topic/6649-ps-pump-modification/
Looks like I can skip the drilling out part and get either the #4 or 3mm washer to put inside the regulator under the spring.
« Last Edit: April 17, 2013, 10:21:06 PM by gif »
Re: Time for Tons
« Reply #130 on: April 18, 2013, 11:25:44 AM »
what did you do to that locker?
is that a lockright?
probably just needed a new cross pin or non worn shims?
Re: Time for Tons
« Reply #131 on: April 18, 2013, 11:47:16 AM »
It is a No-Slip,  supposed to be a quieter and smoother version of a Lockright.
Spec is .140-.170. I'm at .160
I unmeshed both side gears. Held the driver hub while spinning the driveshaft. Pass side teeth would lock right up, drivers side just glide over each other. If I spin the driveshaft in reverse, they lock right up. That's pretty consistent with what I experienced wheeling Sunday. Staying locked after that was iffy, sometimes resulted in unlocking with banging noises.
What would cause that cam gear to not align the teeth? Worn teeth? Worn center pin? Weak springs? It's not like they even tried to lock, just glided over each other like they weren't aligning. Meh
Seriously considering wedging a piece of metal in between the cam gears and welding in place in such a manner that would be easy to remove later... When I buy a new locker. If steering blows cruising around, rock unlocked hubs until I get on the trail.
Re: Time for Tons
« Reply #132 on: April 18, 2013, 11:50:47 AM »
how did the cross pin look?  was there 4 marks two on each side but opposing?
when you check them, the DS should be locked, and do the "spin test"  hold one wheel back, turn the other forward, switch and repeat all 4 directions.
Re: Time for Tons
« Reply #133 on: April 18, 2013, 11:53:20 AM »
The crosspin did not show any visible wear. Did the spin test before wheeling on Sunday, passed without issue. The test I did was to simulate driveshaft spinning with resistance on the driver's tire... and it showed the same results I experienced Sunday with teeth not engaging.
Time for Tons
« Reply #134 on: April 21, 2013, 02:39:35 PM »
#4 washer and orifice drilled to 5/32 blows the end off the steering box.
Awesome
