Author Topic: Time for Tons  (Read 126039 times)
Re: Time for Tons
« Reply #90 on: March 11, 2013, 09:25:15 AM »
I like the wheels also, what are they?
Re: Time for Tons
« Reply #91 on: March 11, 2013, 10:25:04 AM »
Wheels are stock 16" Ford
Probably looking to get into beadlocks ASAP. Thought about welding aluminum rings on these.
Re: Time for Tons
« Reply #92 on: April 11, 2013, 09:36:27 AM »
Left to do:
Lengthen front driveshaft
Rear axle shock mounts DONE
Runs like shit O2 sensor heater circuit fuse blown from MIA downstream sensor, FIXED
Setup rear bumpstops 3/8 plate setup on leaf pads, DONE
Über squishy brake pedal new master installed, SWEET.
After those things:
Trim and hack to make tires fit
Re: Time for Tons
« Reply #93 on: April 11, 2013, 10:26:15 AM »
Sweeeeeet!
Re: Time for Tons
« Reply #94 on: April 11, 2013, 04:04:10 PM »
Sweeeeeet!
Pretty much my feeling, thanks. Jeep, truck, and trailer are all getting a pre-BIG DOGS shakedown up in Mass this weekend.
Re: Time for Tons
« Reply #95 on: April 12, 2013, 09:34:20 AM »
Took this hog for a ride down the road last night. It's a got a couple noises and clunks it didn't before, but all in all not too bad. I am pleased.
Re: Time for Tons
« Reply #96 on: April 12, 2013, 09:49:06 AM »
Very cool can't wait to see it in a week and a half
Re: Time for Tons
« Reply #97 on: April 12, 2013, 10:01:54 AM »
specs on the red 2 door tahoe/yukon?
I used to have one, I miss it  :'(
Re: Time for Tons
« Reply #98 on: April 12, 2013, 10:05:43 AM »
It's actually a 94 2500 Burb. Big block, barn doors. Roomie's tow rig.
Re: Time for Tons
« Reply #99 on: April 14, 2013, 10:50:57 PM »
Got this thing out on some rocks today, didn't do too bad for a shakedown. Definitely was not pushing the limit though. The front locker works about 50% of the time. I did not reuse the side washers per the instructions PDF I found online, but I'm guessing that may have been a mistake. Rear driveshaft is also fully compressing so I plan to add an inch of lift and another half inch of bumpstop.
Should be a reasonable amount to get done before the 24th. I was able to get the fenders trimmed up some more Saturday and all seems well there, no significant rubbing other than on the links.
Couple pics from today.
It was good to be out!!!
« Last Edit: April 14, 2013, 10:59:53 PM by Harrison »
Time for Tons
« Reply #100 on: April 15, 2013, 12:10:07 AM »
Noice!!
Re: Time for Tons
« Reply #101 on: April 15, 2013, 07:30:49 AM »
Short shakedown list.  That's great!
Re: Time for Tons
« Reply #102 on: April 15, 2013, 09:28:31 AM »
So glad I thought saving $150 by buying used was a good idea. Anyone have any insight on this? It is a NO-SLIP which is apparently a little different than the Lockright/Aussie design. The PDF I got says to remove the thrust washers, and says nothing about reinstalling them:
http://www.richmondgear.com/0002pdfs/8221003.pdf
Steps 9, 10 and 15, 16. I actually tried to install the drive gears with the thrust washers in and it would not fit. I realize that sometimes you need to clearance the carrier a little to make them fit though. I suppose the first thing I need to do is find out what the dimensions of their 'test block' (step 32) is. Bah
« Last Edit: April 15, 2013, 09:43:50 AM by Harrison »
Re: Time for Tons
« Reply #103 on: April 15, 2013, 09:43:32 AM »
It's been too long ago for me to remember my No-slip install in a D35.
Call or email tech support and ask your questions.  I'm sure they'd be helpful.
Re: Time for Tons
« Reply #104 on: April 15, 2013, 09:47:31 AM »
Might do that, at least to get the dimensions of the test block.
This came out of a GM 60, same part number is listed for Ford/Chevy on the Powertrax site. They do have a different listing for limited slip though, but it seems to me the LS locker would be smaller?
