Author Topic: Time for Tons  (Read 126213 times)
Re: Time for Tons
« Reply #105 on: April 15, 2013, 10:50:13 AM »
How much would a welded front (just spiders so I can get a locker in later) suck without hydro steering? On smallish tires and high backspacing?
Re: Time for Tons
« Reply #106 on: April 15, 2013, 11:41:47 AM »
i ran my scrambler with 42" tires and a welded diff with a stock CJ power box and what i was told sketchy tie rod angles and things
it was fine
Re: Time for Tons
« Reply #107 on: April 15, 2013, 11:53:14 AM »
good luck cutting spiders out so that you can get a lunchbox in later. I'd say don't count on it.
Re: Time for Tons
« Reply #108 on: April 15, 2013, 11:53:37 AM »
Mostly just worried about being able to turn, period.
Re: Time for Tons
« Reply #109 on: April 15, 2013, 11:56:29 AM »
sell your sole for a locker now and avoid mucho hassel 2X
Re: Time for Tons
« Reply #110 on: April 15, 2013, 12:05:38 PM »
This was my first thought. I spent two hours of axle disassembly time tracking down what ended up being a bad engine-chassis ground on my car so it would start last night, awesome. I will check clearances tonight. If they are out, I think it's worth a shot to get them back in and hope for the best. Else, I will order a new locker.
Lesson frickin learned.
« Last Edit: April 15, 2013, 12:08:04 PM by Harrison »
Re: Time for Tons
« Reply #111 on: April 15, 2013, 12:11:59 PM »
when your rippin down the access trails it gets a little sketchy lol.  But its fine on the trail, I'd do it again in a second.
Re: Time for Tons
« Reply #112 on: April 15, 2013, 12:18:03 PM »
Even pre-hydro? Hmm...
Smike, do you have any connections on lunchbox lockers?
Time for Tons
« Reply #113 on: April 15, 2013, 12:24:43 PM »
Yeah I was welded for 2 years before hydro.  I just unlocked the front when needed.
Re: Time for Tons
« Reply #114 on: April 15, 2013, 12:25:52 PM »
no locker connections, bill doesnt make a 60 yet.
lock right has treated the dakota well and i think they are priced ok
Re: Time for Tons
« Reply #115 on: April 15, 2013, 12:26:42 PM »
Re: Time for Tons
« Reply #116 on: April 15, 2013, 12:33:54 PM »
yup
sell your sole
fucking shoes
* mr.mindless likes this
Re: Time for Tons
« Reply #117 on: April 15, 2013, 12:50:23 PM »
i meant sell everything including the dirt you stand on!   duh!
Time for Tons
« Reply #118 on: April 15, 2013, 01:45:32 PM »
Build your credit! lol
Time for Tons
« Reply #119 on: April 15, 2013, 07:50:24 PM »
Spec is .140-.170. I'm at .160
I unmeshed both side gears. Held the driver hub while spinning the driveshaft. Pass side teeth would lock right up, drivers side just glide over each other. If I spin the driveshaft in reverse, they lock right up. That's pretty consistent with what I experienced wheeling Sunday. Staying locked after that was iffy, sometimes resulted in unlocking with banging noises.
What would cause that cam gear to not align the teeth? Worn teeth? Worn center pin? Weak springs? It's not like they even tried to lock, just glided over each other like they weren't aligning. Meh
Seriously considering wedging a piece of metal in between the cam gears and welding in place in such a manner that would be easy to remove later... When I buy a new locker. If steering blows cruising around, rock unlocked hubs until I get on the trail.
