Author Topic: Time for Tons  (Read 107730 times)
Re: Time for Tons
« Reply #135 on: April 21, 2013, 04:04:11 PM »
:o
Time for Tons
« Reply #136 on: April 21, 2013, 04:17:25 PM »
Sounds messy.
I saved the steering box off the dump bus...
I bet the mounting pattern is bigger though, I don't have stock jeep/dak to compare to.
Time for Tons
« Reply #137 on: April 21, 2013, 04:17:38 PM »
(better here than there!!)
Time for Tons
« Reply #138 on: April 21, 2013, 04:39:48 PM »
Reid had a box from the frame donor TJ he got. It's in, washer removed, back together and running. No issues going lock to lock now. I locked the hubs and it seemed to steer fine. Wonder if smallish tires and lots of backspacing make it tolerable.
Re: Time for Tons
« Reply #139 on: April 21, 2013, 05:56:20 PM »
Hmmm, would not have thought that would be a fail point. ???
Time for Tons
« Reply #140 on: April 21, 2013, 05:56:35 PM »
She dun straight blown up!
Good it did it pre BD
Re: Time for Tons
« Reply #141 on: April 22, 2013, 12:25:05 AM »
that is a good trick!
Re: Time for Tons
« Reply #142 on: April 22, 2013, 07:46:05 PM »
a direct bolt on and larger box is a 98-99 durango with the snopackage,iirc
Re: Time for Tons
« Reply #143 on: April 29, 2013, 11:16:43 AM »
I have read about the Durango box, may do that. Steering power was very acceptable all weekend. Pitman issue us going to have me scratching my head, plan for now is to replace with a factory Waggy arm and see what happens.
Needs the D20 either rebuilt or replaced, new trans pan, exhaust unsquished from belhousing before wheeling again. Bonuses would be full rear crossmember for a full belly skid and D20 to mount to as well as a skid from the crossmember forward (like Smike builds for TJs) to protect trans pan, exhaust, and oil pan.
Overall, I am very pleased with how this thing performed this weekend. Being out with the buggies made me realize that putting my Jeep on 40s is not necessary because it is still not going to go where they go without a lot more power and a lot less body, two things I'm not interested in changing at this point. I would rather start over with something with a frame (frame on body with added tube or just a buggy) if I ever want to run 40s.
I really like the width I'm at, so I am going to scoop up my buddy's stock Ford steel wheels and weld beadlocks on them, throw my current 36s on. When they are chunked bad enough/get sliced open/I get sick of them and have cash I would like to spend good money on some 37s (blue labels, Creepies, maybe kevlar MTRs, something along those lines) and be done with it.
Tons are fucking awesome.  ;D
Re: Time for Tons
« Reply #144 on: April 29, 2013, 11:22:23 AM »
looks awesome.  made my buggy look bad on insanity.
made nicks 30 look terrible on KGB
:)  i like it
Re: Time for Tons
« Reply #145 on: April 29, 2013, 11:25:00 AM »
QFT!!!!!!!!!
this thing did work.
Re: Time for Tons
« Reply #146 on: May 21, 2013, 11:47:33 AM »
(2) races, (2) bearings, (2) seals for a 1975 Bronco D20 are about $55.
Smike, based on your experience, is that likely all I need?
Re: Time for Tons
« Reply #147 on: May 21, 2013, 11:50:13 AM »
i have never serviced, just bolted on used stuff from spare cases.  seems like you could get another D20 for 50$ at least thats what there were back in my day of collecting them.
if the output shafts are hosed or galled up new bearings might not help.
Re: Time for Tons
« Reply #148 on: May 21, 2013, 11:53:47 AM »
D300 and done..
but yes about what said and what smike said...
Re: Time for Tons
« Reply #149 on: May 21, 2013, 11:56:25 AM »
Ok, guess I need to do some disassembly before I order anything.
Granted I haven't looked very hard, but I don't see many Bronco D20s on the market. My wanted ad on Pirate got deleted.
Why would I get a D300? The D20 is already twin stick and ACTUALLY a driver's drop case... no silly flipping required
