Author Topic: M4wdriveway Yota Exo  (Read 139985 times)
Re: M4wdriveway Yota Exo
« Reply #465 on: June 12, 2014, 01:53:12 PM »
It's a push/pull double acting in both cases (or a double ended )but still same plumbing and mechanics. Lower volume coming out if a steering box hence smaller is needed - and there's already assist in the box too.
« Reply #466 on: June 12, 2014, 01:57:39 PM »
Gotcha
« Reply #467 on: June 24, 2014, 04:38:00 PM »
« Reply #468 on: August 10, 2014, 08:56:58 PM »
Well that lasted about 15 minutes
« Reply #469 on: August 10, 2014, 09:44:40 PM »
Wtf?
« Reply #470 on: August 11, 2014, 07:48:32 AM »
Jared rocks were too big
« Reply #471 on: August 11, 2014, 09:44:28 AM »
took a step down from proven material- did you expect much else lol
« Reply #472 on: August 11, 2014, 09:54:42 AM »
I expected more then that lol.  I wasn't even bound up.
I've been running the trail gear "better then stock" since it was built, which were dirt cheap like $60.  I guess those held up pretty good.  Trail-gear has discontinued them since bought Longfield.
« Reply #473 on: August 11, 2014, 09:58:38 AM »
[pirate naysayers]
cant run tires that big on stock axles
[/pirate naysayers]
« Reply #474 on: August 11, 2014, 10:00:07 AM »
cant take the power of the 22re
« Reply #475 on: August 11, 2014, 10:01:08 AM »
you cant run toyota axles with anything bigger than a 29" according to pirate lol
« Reply #476 on: August 11, 2014, 10:12:52 AM »
I can get Longfield 27 spline birfield for $120 a piece.  Probably the way I'll go, should last a year or two.
Longfield 30 spline kit $700 isn't in this summers budget...  would have to think real hard about those or time-for-tons at the point
« Reply #477 on: August 11, 2014, 10:15:44 AM »
i got 4.56 chevy tons and 42 TSLs would work real good on that hawg
« Reply #478 on: August 11, 2014, 11:24:08 AM »
damn. I thought this was a tried and true stock axle machine
« Reply #479 on: August 11, 2014, 11:30:08 AM »
$700 in longs, or same in axles, just need to fill em with 5.38s.
