Author Topic: M4wdriveway Yota Exo  (Read 139929 times)
Re: M4wdriveway Yota Exo
« Reply #435 on: June 04, 2014, 04:42:59 PM »
he has a CV at the case, and 25 degrees at the diff unjoint
« Reply #436 on: June 04, 2014, 05:00:51 PM »
Prolly more like 45 lol.  What if I just put a reg joint in?
« Reply #437 on: June 04, 2014, 05:03:06 PM »
reg joint would get case and diff closer to sync, if it will take the current angles
« Reply #438 on: June 05, 2014, 10:10:22 AM »
Whats up with my steering.  steering wheel turns and wheels dont.  Pump shitting the bed?
« Reply #439 on: June 05, 2014, 12:03:58 PM »
steering valve shitting the bed. if it was fluid starved but otherwise good it should be hard to turn.
« Reply #440 on: June 05, 2014, 12:30:26 PM »
orbital should be the only good part of the steering system...
« Reply #441 on: June 05, 2014, 12:37:27 PM »
wrong ram, shaft is way to big.  i suspect air in lines also.
« Reply #442 on: June 05, 2014, 12:37:46 PM »
Maybe it's pissed that you took it out of the garage? LOL
my CJ steering would get cranky after sitting for long periods. But always seems to clear it self after some driving.
Is it worth fluid replacement?
« Reply #443 on: June 05, 2014, 12:50:20 PM »
You told me to get that one lol.  Idk its been bleed pretty thoroughly.  This is a new symtom, before it just wouldn't turn at low rpms.
« Reply #444 on: June 05, 2014, 01:06:37 PM »
2X6X1.25 DA HYD CYL SWIVEL EYES I believe this is the unit I have
http://www.surpluscenter.com/Hydraulics/Hydraulic-Cylinders/Double-Acting-Hydraulic-Cylinders/2X6X1-25-DA-HYD-CYL-SWIVEL-EYES-9-7259-6.axd
1.25 seems to be pretty common shaft size at 2".  What were the single ended ones you guys were running? or were then 2.5"
« Reply #445 on: June 05, 2014, 01:37:23 PM »
Trapped air would surely do it.
Raise the front tires off the ground. Bring it lock to lock 3-4 times every time you're out in the garage over a week. Ought to bring any air out easily.
« Reply #446 on: June 05, 2014, 01:52:52 PM »
got bleed air at the ram with that ram up, the volume of his cylindar is way to small
« Reply #447 on: June 05, 2014, 02:36:13 PM »
I will try it again
« Reply #448 on: June 05, 2014, 02:37:50 PM »
What did/are you guys running for SE cylinders?  2.5 x 1.25?
There only like $60 I'll get another and dump this one lol
« Reply #449 on: June 05, 2014, 02:42:04 PM »
a non swivel eye cylinder would also semi-fix my tie rod problem.
