Author Topic: M4wdriveway Yota Exo  (Read 139932 times)
Re: M4wdriveway Yota Exo
« Reply #450 on: June 05, 2014, 03:01:23 PM »
2" but not one with a 1.75" shaft
« Reply #451 on: June 05, 2014, 03:06:22 PM »
http://www.tractorsupply.com/en/store/hydraulic-cylinder-2-bore-x-8-stroke
2" bore, 1.25" shaft (which seams even too big what i recal)
i have a used one on the shelf
« Reply #452 on: June 05, 2014, 03:27:00 PM »
thats what I have 2" X 1.25"...
« Reply #453 on: June 05, 2014, 03:29:37 PM »
correction- the TSC ram is 2" bore 1 1/8"shaft- i thought mine was more like a 3/4 - 1" shaft
« Reply #454 on: June 05, 2014, 03:33:58 PM »
I'll measure mine tonight to double check.  Thats all they have on the surplus website in 6" stroke unless they discontinued it...
« Reply #455 on: June 05, 2014, 03:34:38 PM »
ill look at what i have on the shelf too.
« Reply #456 on: June 06, 2014, 09:23:30 AM »
Confirmed
« Reply #457 on: June 06, 2014, 11:13:44 AM »
2"X x 1.056' shaft is on my shelf
« Reply #458 on: June 06, 2014, 11:21:49 AM »
weird, it seems the 1" shaft has been abandon by all.
Whats on your shelf and 8" throw?  For sale?
« Reply #459 on: June 09, 2014, 08:48:11 AM »
Fuel put back together.  Pump is silent, 40 psi at the rail.
I think my u-joint noise was the carrier bearing guard that was smooshed up tight against the flange.
Did a steering inspection, I see a couple potential issues.  Cooler height may have been above the pump, moved.  cylinder is mounted with the ports off the back, potential for air?  I don't however see any "frothiness" in the reservoir that would indicate air in system...   Does whine pretty bad though.
JWOK
  • Full Member
« Reply #460 on: June 11, 2014, 07:49:07 PM »
I gots a 1.75 8" I would like to get rid of. Then I can get a 1.5 6" on the jk.
« Reply #461 on: June 12, 2014, 12:07:36 PM »
assist cylinder is different than full hydro cylinder correct?
« Reply #462 on: June 12, 2014, 12:14:18 PM »
usually run a smaller cyl in assist.
« Reply #463 on: June 12, 2014, 12:40:11 PM »
No mechanical difference?
« Reply #464 on: June 12, 2014, 01:11:31 PM »
none.
