Author Topic: 2003 Ram 2500 CCLB  (Read 142958 times)
Re: 2003 Ram 2500 CCLB
« Reply #375 on: June 23, 2025, 06:17:43 PM »
in my experience, impossible to find squeaks are usually the center pin in a front CV shaft. usually found shortly after friction welding themselves together and exploding.
« Reply #376 on: June 23, 2025, 06:24:46 PM »
probably a CAD axle that doesnt spin front shaft in 2wd though
« Reply #377 on: June 23, 2025, 07:02:41 PM »
good point
« Reply #378 on: June 24, 2025, 08:04:41 AM »
3rd gens did not have CAD - and about once every month or two I see a horror story on the 3rd gen Cummins Facebook page where someone is on the side of the road after their front driveshaft double cardan came apart. Transfercase blown apart, holes torn in floor, wiring and plumbing along frame rail torn and dangling.
There is a sticker on the rad crossmember about greasing the pivot ball in the front double cardan but the fitting is apparently very hard to find. I rebuilt my front driveshaft and put lockout hubs in and I admit I have never bothered with it  ::)
« Reply #379 on: June 24, 2025, 08:23:17 AM »
same note on my 4500s drive shaft.  there are no fittings to grease.
« Reply #380 on: June 24, 2025, 08:24:17 AM »
but good info.
easy enough to remove it for diagnosis.  ebay drop in replacements should be cheap to swap if needed.
« Reply #381 on: June 24, 2025, 01:38:24 PM »
Driveshaft and transfer case explosion was the first major automotive surgery (beyond brake jobs and bolt-ons) and relative self recovery I did. Was a great way to spend Christmas break of I think sophomore year learning about input shaft lengths and spline counts and gear cutting changes that limit interchange.
Popped in Sandusky Ohio on 12/23 whatever year.
« Reply #382 on: June 24, 2025, 01:39:51 PM »
Not sure if it’s still true but they were one of the only ways to rent any sort of vehicle before turning 25 back then.
« Reply #383 on: June 25, 2025, 11:10:25 AM »
Good info, will check.
« Reply #384 on: June 27, 2025, 09:27:18 AM »
Everything's a project!  Good exercise though, if I ever had to pull it out on the side of the road I would have been unprepared and I'm sure its well past it grease interval and it appears my font pinion seal leak is getting bad enough I should attend to it.
It spins by hand pretty easy with no sign of slop.  The t-case side bolts came out real easy.  Shaft is stuck to the flange though, I didn't try real hard yet.  For the axle side, my T40s are all too short and I don't want to strip them.
Ordered long T40 and a grease injector needle.
I see they sell hex bolts to replace the T40's.  At $6 a piece and $14 shipping.  That's a bit steep and I'll have the correct tool now anyways...
On another topic, I greased everything I could find.  I could not get the top ball joints to accept any grease.  Any tips?
« Reply #385 on: June 28, 2025, 11:42:40 AM »
I got some grease in there.
Sent from my iPad using Tapatalk
« Reply #386 on: June 28, 2025, 09:54:42 PM »
the pinion seal trick is to take a cut wheel or rotary tool of some sort to cut a small reference mark on the pinion shaft and pinion nut.  so that you can remove the nut, pull the flange, change the seal, put back and have the same preload on the pinion by tightening down to only where your marks match up and no further.
taking it off and then running it back home you risk over crushing a crush sleeve if its not something you do daily.  then bearings kaboom.
« Reply #387 on: June 29, 2025, 11:51:18 AM »
Removed.  Non-greaseable pivot ball, which I assume means it’s been replaced.  All free, no play.  Reinstalled.
« Reply #388 on: June 29, 2025, 11:54:11 AM »
I’ll order the pinion seal and drop it off :)
« Reply #389 on: July 01, 2025, 01:55:48 PM »
Am I missing something here or is the 1. Pinion seal and 5. Pinion seal sleeve one piece?
