Author Topic: waste oil burn  (Read 79064 times)
Re: waste oil burn
« Reply #15 on: November 11, 2019, 01:11:54 PM »
i was gona start with the small shop vac. i did read they really arent 100$ duty rated.  if the end solution is noisy, i can just put it down stairs.  i have a few marine inline blowers that are DC and much cheaper to control speed also.   I might even have an extra air pumper from the brolite somewhere.
120v mattress pump might do it.  i have only used the junk 12v ones
Re: waste oil burn
« Reply #16 on: November 11, 2019, 01:54:27 PM »
troy in your ventures what was the gal/hour you were burning about?  didnt know you tried the air pump version
Re: waste oil burn
« Reply #17 on: November 11, 2019, 01:55:59 PM »
I had considered the marine blower, but hacked a computer psu and got the highest cfm computer fan they make, problem was trying to cram a 4" fan down a 1 1/4" pipe, there was too much back pressure and no matter if the fan was on low or high same amount of air traveled through,whereas a shopvac or mattress pump force air no matter the size of you air intake
Re: waste oil burn
« Reply #18 on: November 11, 2019, 01:56:51 PM »
squirrel cage blower from auto HVAC could be plumbed too if 12v is on the table, or a household furnace blower for 120v.
Re: waste oil burn
« Reply #19 on: November 11, 2019, 02:00:16 PM »
At full blast I think I was at 1gal per 2 hours
Re: waste oil burn
« Reply #20 on: November 11, 2019, 02:03:09 PM »
im shooting for 1-1.5gal per hour burn
Re: waste oil burn
« Reply #21 on: November 11, 2019, 09:09:44 PM »
burned a load of wood through this tonight, should be ready to vac out tomorrow cool and start working on waste pot
Re: waste oil burn
« Reply #22 on: November 12, 2019, 07:27:41 AM »
trying to pick up a bounce house blower today after work.  high hopes!
Re: waste oil burn
« Reply #23 on: November 12, 2019, 12:22:31 PM »
bounce house blower is a monster!  its HD
Re: waste oil burn
« Reply #24 on: November 12, 2019, 01:11:07 PM »
oil burning forge?  ;D
Re: waste oil burn
« Reply #25 on: November 12, 2019, 01:23:04 PM »
oh boy
Re: waste oil burn
« Reply #26 on: November 12, 2019, 07:49:39 PM »
lots of fail tonight.  cant get enough fuel to burn.  need to research importance of pot size / shape ect.
Re: waste oil burn
« Reply #27 on: November 12, 2019, 08:29:46 PM »
pot size and shape isnt really important ,heat is, are you having problems just igniting or continued burn?
Re: waste oil burn
« Reply #28 on: November 12, 2019, 08:39:58 PM »
tarps in the car next time I come south.
Re: waste oil burn
« Reply #29 on: November 16, 2019, 02:53:19 PM »
had this thing ripping for about an hour pretty good with a new pot style.  it appears the variable speed drive has killed my bounce house blower.  sad face!
