Author Topic: waste oil burn  (Read 78963 times)
Re: waste oil burn
« Reply #135 on: November 23, 2024, 03:12:50 PM »
first two days of burning this season.
messed with the Peristaltic pump i had and found inlet to be clogged with grit.  added a pump screen, will source spare tubing.  its working nice right now.
https://youtu.be/HX3kJhXAk-k?si=Gd6UbkoGY8ZDXBno
Re: waste oil burn
« Reply #136 on: November 23, 2024, 03:44:55 PM »
for reference i have determined that the current tubing on the pump is
"BPT tube 4.8 mm ID x 8 mm OD"
46$ for 1m of it bah
Re: waste oil burn
« Reply #137 on: February 26, 2025, 11:00:31 PM »
found the bottom of my 270 gal tote today.  pumped last 3 drums i have into it.  might make it through the rest of the winter hopefully!
about 450 gals burned so far this winter i believe
Re: waste oil burn
« Reply #138 on: February 27, 2025, 12:52:52 PM »
I got hoses to dump from totes across shop into furnace tank. Cracked into the second tote last week, on top of already having pumped 4-6 barrels.
Has been a chilly winter!
Was quite annoying to have almost a full drum of water out of that batch of barrels.
Re: waste oil burn
« Reply #139 on: February 27, 2025, 02:43:56 PM »
ya i had some junk last year and i was a bit more picky this year.  finding equipment guys is best.  they can load drums and have lots of it, and clean oil.  i have 3 sources in buffalo that yeild a couple drums every season now.
Re: waste oil burn
« Reply #140 on: September 29, 2025, 02:28:38 PM »
scored some used 6" stainless flew pile, rain cap, tee, trim ring for 100$ today!   was pricing out new local at 450+
installed.
Re: waste oil burn
« Reply #141 on: October 22, 2025, 12:53:20 PM »
how's your oil stock? I think I have 2 years on hand right now after picking up 3.5 on Friday from my best regular. Have I think 6 barrels of capacity open. both totes full. full furnace tank. and I think 15 drums full.
Just about out of home heating oil though, might have to pay retail price fuel to mow next year for the first time if I don't find some.
Re: waste oil burn
« Reply #142 on: October 22, 2025, 01:27:10 PM »
i have a good year in a half on hand, and have 300gals to pick up clean oil to pickup next week, and about 80 gals of heating oil to pick up
so i am good for now
im planning to play with beckett burner guns this winter with some red fuel before converting to WMO
Re: waste oil burn
« Reply #143 on: November 04, 2025, 02:09:30 PM »
pumped out a tote that was about 20gals bigger than my large totes..  made about a 5 gallon mess before i could hit the shut off.  truck is blasted.  at least it was on a gravel lot....
bah
Re: waste oil burn
« Reply #144 on: November 05, 2025, 03:55:37 PM »
shoveled off oil dry, doused with dish soap and scrubbed with a broom today while it was raining pretty good.  hoping the problem will be gone tomorrow ha
