Author Topic: waste oil burn  (Read 78955 times)
waste oil burn
« on: November 09, 2019, 05:42:30 PM »
i have been looking at some options.   buy a real furnace new, buy a used one, make something meh
did some bench tests with some high pressure nozzle burners today.  i think i need to step up my game if im going to do it.
Re: waste oil burn
« Reply #1 on: November 09, 2019, 07:23:26 PM »
i am thinking a double barrel style stove i can put a waste oil pot styled burner in and still be able to burn wood or cardboard shit from shop
https://www.youtube.com/watch?v=2hyr27W7Xzk
Re: waste oil burn
« Reply #2 on: November 09, 2019, 08:55:15 PM »
That’s pretty cool
Re: waste oil burn
« Reply #3 on: November 09, 2019, 09:04:07 PM »
might be a futile attempt and not neat enough heat
have lots of oil, fans, and 55 gal drums so might be worth a try.
Re: waste oil burn
« Reply #4 on: November 10, 2019, 07:35:13 AM »
I did a double barrel stove like that and wasn't to happy with how looking it lasted.  I think I got two or three years out of it.  The metal is just to thin and doesn't last. I seen one guy take a 250 gallon heating oil tank and make a big furnace.
Re: waste oil burn
« Reply #5 on: November 10, 2019, 11:24:57 AM »
...The metal is just to thin and doesn't last.
That's what I was thinking
Re: waste oil burn
« Reply #6 on: November 10, 2019, 08:30:01 PM »
picked up a barrel kit and double barrel kit from TSC today, also stopped at lowes for some misc items.
plan is a double barrel kit with wood or waste oil option.
need to grab some sand / bricks tomorrow and ready for first burn / clean out, then start tweeking the waste oil forced air setup.
Re: waste oil burn
« Reply #7 on: November 10, 2019, 10:31:11 PM »
whats your oil pot look like and how are you feeding it air?
Re: waste oil burn
« Reply #8 on: November 11, 2019, 08:10:13 AM »
oil feed will be 1/4" copper line inside a 1.5 or 1.75" steel tube.  the tube will have a shop vac blower hooked to it with a variable speed drive.
sizes for oil line and air line will mostly be driven by the junk i have laying around.  will tweek later but basically you need to be able to throttle the oil and air to get a good burn.  shooting for 1-1.5 gallon per hour burn should be more than enough to max out heat from the two drums with fans on them.
after that i might try a compressed air / mixer nozel setup but they look more of a pain to light/ control and you have to listen to your air compressor kicking on a lot.
Re: waste oil burn
« Reply #9 on: November 11, 2019, 08:11:59 AM »
pot will be literally an old trailer cooking pot or whatever the biggest thing i can fit though the barrel door.
Re: waste oil burn
« Reply #10 on: November 11, 2019, 09:03:49 AM »
it always amazed me how you think of something and it just happens...
Re: waste oil burn
« Reply #11 on: November 11, 2019, 09:57:54 AM »
You know of any backroad routes from mine to yours? I hear stories from those who go south that Scottsville and E River can both take an hour to get to I90 in a bad snowstorm. Sitting in traffic is totally not what an offrAudi is for. It's for sending me into the ditch when I get overconfident in my abilities while running around in a snowstorm because I don't have to care about road conditions!
Re: waste oil burn
« Reply #12 on: November 11, 2019, 11:57:07 AM »
i see zero traffic at 3:45 everyday.  between 4:30 and 6pm every week day its back up past my house and down the road from the village signal
not really sure any other way haha
Re: waste oil burn
« Reply #13 on: November 11, 2019, 12:13:27 PM »
I'll may be running around a bit after work. someone misplaced her keys and isn't testing out the new snow tires just yet.
Re: waste oil burn
« Reply #14 on: November 11, 2019, 12:29:04 PM »
i started off with a shop vac, but its way to loud and if i fried the motor its a wasted $70 ,walmart has plug in mattress pump for $10, put it in a box surrounded by insulation with vents and its  near silent with mass air flow
