Author Topic: Troys new Truggy Chassis  (Read 96402 times)
Re: Troys new Truggy Chassis
« Reply #195 on: August 30, 2013, 02:48:09 PM »
should over flow when warm, but will overflow when ram is fully compressed
« Reply #196 on: September 04, 2013, 09:44:14 AM »
when is the shake down run before rausch?  talk you your buddy about work land?  need it hawged somewhere this weekend?
« Reply #197 on: September 05, 2013, 10:55:15 PM »
not to bad of a maiden run,1st thing to do fix leaks,2 affix roof tin better,3 hook up altenator properly,4 bleed radiator
« Reply #198 on: September 05, 2013, 11:31:58 PM »
she hawgs pretty good.  couple bugs.
where is the night jumps of 572.  need limit straps installed stat
« Reply #199 on: September 06, 2013, 09:17:29 AM »
now i need a pigtail
« Reply #200 on: September 06, 2013, 09:25:20 AM »
didn't burn, did it?
« Reply #201 on: September 06, 2013, 09:40:49 AM »
Just need power to s and f.
« Reply #202 on: September 06, 2013, 09:53:09 AM »
I picked up 2 volts running S to the battery
« Reply #203 on: September 06, 2013, 09:59:05 AM »
we tried that, no go
« Reply #204 on: September 06, 2013, 10:33:16 AM »
We tried running hot to both at the same time?
« Reply #205 on: September 06, 2013, 10:40:40 AM »
yes, i did
« Reply #206 on: September 06, 2013, 10:47:54 AM »
should i try wire it seperately like in the pic,i dont understand how jeff only has 1 wire
« Reply #207 on: September 06, 2013, 03:56:44 PM »
one wire alt is a different setup, it's got a diode inside or somesuch to keep from drawing down the battery
« Reply #208 on: September 08, 2013, 06:38:51 PM »
New alt in and pigtail from j&j,charging like a champ.tranny seals and t-c seals in so far no leakies,started putting in more roof tabs in.radiator was pretty much empty filled up let it run all kinds of bubbles ,ready for another shakedown
« Reply #209 on: September 09, 2013, 02:20:22 PM »
You coming to Rausch?
