Author Topic: Troys new Truggy Chassis  (Read 96166 times)
Re: Troys new Truggy Chassis
« Reply #180 on: August 25, 2013, 08:15:03 PM »
i dont remember it reading any pressure with just key on, already in the box ready to be returned, never got over 10psi, its definately defective
this is the one i got
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_x_18770076-P_x_x?cm_mmc=ACQ-_-Google-_-enhancedRM-_-18770076&ci_src=17588969&ci_sku=18770076&ci_gpa=pla&ci_kw=&gclid=CO-rzJzqmbkCFYSf4Aodxl8A-g
1 review a guy uses it for a tbi
« Reply #181 on: August 25, 2013, 08:22:53 PM »
that is your problem sir, wrong pump
you need much more pressure than that to feed the TBI
« Reply #182 on: August 25, 2013, 08:25:39 PM »
your kidding, isnt a tbi max pressue 14psi?
« Reply #183 on: August 25, 2013, 08:31:07 PM »
E2000 Fuel Pump- 100psi/40gph -45psi/25gph
$35 on egay
« Last Edit: August 25, 2013, 08:39:33 PM by gif »
« Reply #185 on: August 25, 2013, 08:47:38 PM »
you need >>14psi because the regular bleeds at 14psi....
« Reply #186 on: August 25, 2013, 08:51:50 PM »
this is what 572 ran all weekend on no issues
http://www.ebay.com/itm/111124259171?item=111124259171&viewitem=&sspagename=ADME:L:OC:US:3160&vxp=mtr
Matts is in the shop if you want to grab it and order another one
i tapped the end out to 1/8 NPT (for a hose barb) instead of the banjo bolt thing it game with
« Reply #187 on: August 25, 2013, 08:58:12 PM »
Get an E2000 from Autozone tomorrow, use a promo code on line and pick up in store, be don ein 10 minutes and not wait 5 days for something shipped to you. It worth the extra $12.
« Reply #188 on: August 25, 2013, 08:58:49 PM »
Thats what my buggy has.   I used swagelok to stainless hardline and -6 AN Braided Stainless Steel Fuel Line Hose
« Reply #189 on: August 25, 2013, 09:02:47 PM »
thanks, ordered. will see how long it takes to get here would like to be ready for test run this weekend, finished some to do over the weekend harnesses will be here tomorrow
« Reply #190 on: August 25, 2013, 09:07:14 PM »
ours were here in 3 days, but like i said one at the shop matt wont need for a whille
« Reply #191 on: August 30, 2013, 11:27:54 AM »
Welp,put the new pump in holding steady at 14 psi,back it out of the garage then floored it no hesitation under load,back up again and floor it 10 ft later it dies and smoke starts pouring out of the ignition coil,fml
« Reply #192 on: August 30, 2013, 11:35:22 AM »
Hey! I know what the problem is this time!
« Reply #193 on: August 30, 2013, 02:06:02 PM »
100 of those at J/J make sure your alternator isnt smoked or over charging
« Reply #194 on: August 30, 2013, 02:46:56 PM »
meh picked new one up for 20 beans,did a couple laps around the yard runs pretty good, died once out of a dozen times at full throttle. think it needs more atf seems to wind up and take off,gotta drop the t-c a little bolt is getting hung up on the cross member and wont let me shift,definately need a power steering rezy overflowing when warmed up
