Author Topic: Troys new Truggy Chassis  (Read 96168 times)
Re: Troys new Truggy Chassis
« Reply #150 on: July 31, 2013, 10:16:07 PM »
Trade A pair of 4" bumps for your spare orbital?  Text me a pic of it if you can.
Saw your pics on Facebook looks good. Are you going to be ready for Rausch in August?
« Reply #151 on: August 01, 2013, 08:59:36 AM »
i could do that trade,i need your # again got a new phone.if the yokes get here when they say they do a aug trip is definate
« Reply #152 on: August 01, 2013, 09:14:22 AM »
585-978-4540
« Reply #153 on: August 08, 2013, 07:22:02 PM »
no tracking #from bronco graveyard yet,a aug trip is looking pretty bleak atm
« Reply #154 on: August 10, 2013, 08:21:36 AM »
did you call?
they emailed me right away and said they were out of stock, but gave me a back order date they beat in the end
« Reply #155 on: August 10, 2013, 09:00:26 AM »
tracking # received,be here tuesday
i called once i saw it was backordered,instead of being dropshipped from the mannie it musta been sent to them first
« Reply #156 on: August 10, 2013, 09:07:37 AM »
cool
« Reply #157 on: August 18, 2013, 04:15:53 PM »
put a rear shaft in last night,drove it around the yard today.stuttering pretty bad under full throttle, double checked firing order had 2 wires mixed up,runs better but still stuttering under w/o, timing?i dont know. idle isnt steady kinda revs up and down.good leak from tailshaft gotta replace the bushing, good leak from front output shaft not sure what has to be done for that. gotta readjust tranny shifter have no park, brakes good but a little soft,need a steering resevoir starving a little on full lock,
other to do:
harnesses
skid plate
front shaft and crossmember
roofbars
« Reply #158 on: August 18, 2013, 04:39:05 PM »
Chk your static timing at idle. Coolant temp sensor can do weird shit. so can the knock sensor. Sounds familiar to early 571 issues.
« Reply #159 on: August 18, 2013, 04:48:59 PM »
smike gave me a new coolant sensor that i put in,knock sensor is the same location as 571,if its timing id need help with that ,dont know anything about how to set timing
« Reply #160 on: August 18, 2013, 11:33:49 PM »
TBI motors do there own thing on timing-  could be O2 issue, TPS, or Map issue.  is the fuel pressure good and return line flowing back to cell?  Pickup in distributor also rots out and that can mess shat up
« Reply #161 on: August 19, 2013, 12:18:13 PM »
Did some googling,thought it might be open vacuum but plugged those no change.gonna grab a in line fuel guage and swap map sensors when I get home.it backfires through the tbi does that mean its getting too much fuel, leaky injector or plugged regulator?
« Reply #162 on: August 19, 2013, 12:19:36 PM »
My guess is timing if its backfiring thru the intake
« Reply #163 on: August 19, 2013, 12:42:11 PM »
did you pull the distributor out at all or is it how it was?
« Reply #164 on: August 19, 2013, 12:45:23 PM »
Never touched it,put new plugs and wires,that's it
