Author Topic: Troys new Truggy Chassis  (Read 85234 times)
Re: Troys new Truggy Chassis
« Reply #165 on: August 19, 2013, 12:56:08 PM »
stick your finger over spark plug hole1 till you feel pressure and it stops while rotating crank, stop rotating crank
pull the dist cap and make sure rotor points near 1
mark on balancer should be around 1:00 when this occurs.
check 1, 8, 4, 3, 6, 5, 7, 2 fire order
« Reply #166 on: August 19, 2013, 10:03:13 PM »
got home changed the map sensor ,no change.looked at the dist cap it was cracked on one side,pulled it off everything looked pretty beat so went and got a new one, no change. located tdc, tried it three times and this is where it lands,if you cant tell it lands on the 1st notch in
« Reply #167 on: August 20, 2013, 05:29:44 PM »
So according to that notch I'm at 10 deg before ,fresh ain't it suppose to 0?
« Reply #168 on: August 20, 2013, 08:43:23 PM »
im so f'in lost.timing gun procured,im thinking the balancer musta slipped cause at 0 deg this thing will barely start let alone run.even if i turn the distributor till it runs decent the injectors are just pouring gas on the butterflies it backfires then they just become flame throwers.
« Reply #169 on: August 20, 2013, 08:49:19 PM »
Flame throwers!!! Yes
« Reply #170 on: August 20, 2013, 09:08:29 PM »
quiet you!
new information,apparently you have to unplug a brown/black wire first if you mess with the timing,will give it a shot tomorrow if that doesnt help prolly should look into a new iac or tps.dont mind me just thinking out loud here
« Reply #171 on: August 24, 2013, 08:18:46 PM »
so sick of this thing,another weekend wasted.went to j&j yesterday pulled a shatload of sensors even got a regulator and injectors.ive replaced all the sensors to no avail,different regulator and injectors ran worse if at all, only things i havnt replaced is 02 sensor which should be fine since it was on 571,distributor and coil pack,knock sensor.i got a tbi gasket kit and replaced everything.and now the battery keeps dying,i took it in last week they tested it and it was fine so i bring the alt in and thats fine too,wtf >:(. ive read it could be ground issues too so i cleaned things up added more grounds went through my wiring to find any loose connections.if this thing isnt running right after sun this shit is getting pulled out and a trusty ford 351 is going in ,fuck this chevy shat
« Reply #173 on: August 25, 2013, 12:16:23 AM »
« Reply #174 on: August 25, 2013, 07:52:07 AM »
my 1st problem is the directions i followed didnt mention much of the aldl when i weeded the harness so it got cut out(i thought it was from the steering column)which isnt a big deal i left enough wire i could get the plug and wire it back in.
my 2nd problem, even if iwire it back in 99% of the guys ive read experiencing  the same symptoms never get a cel
3rd problem is it literally can be anything, bad fuel pump,clogged filter,map,cts,tps,02 sensor,ecu,vacuum leak,bad wires cap or plugs,bad magnets in the dist,bad injectors or regulator,bad grounds or altenator,iac,
my symptoms,runs fine when cold no stumbles,wot sounds mint,once warm still runs fine at idle,still not sure whether the injectors should be a pulsing spray or constant ,mine are constant.once you put it in gear and hit the gas falls right on its face and may die ,or it may stumble back,backfiring through the tbi doesnt seem to happen much anymore
« Reply #175 on: August 25, 2013, 10:54:56 AM »
Did you check the air in the tires?
« Reply #176 on: August 25, 2013, 06:01:59 PM »
Welcome to the last year and a half of my life :/
« Reply #177 on: August 25, 2013, 07:15:10 PM »
think i just found the problem,got a fuel pressure guage on it,idles at 9-10 drops to 5 or less under load.other news its now 4wd got a front shaft in
« Reply #178 on: August 25, 2013, 07:55:39 PM »
should be 14 ish, thats about what the regulator in in the pod should be... whats the fuel pressure with pump on and motor off?
« Reply #179 on: August 25, 2013, 08:07:30 PM »
The feed side pressure should be about 13psi and should not change with rpm or load. The return should be near 0psi.
