Author Topic: Troys new Truggy Chassis  (Read 96354 times)
Re: Troys new Truggy Chassis
« Reply #120 on: June 12, 2013, 09:43:04 PM »
i have no idea what your talking about,i went to that forklift repair on mt read,asked the guy if he had any orbitals and he pulled this char lynn  p.o.s out of a pile and said here you go
according to to 10 youtube videos i watched flaring aluminium just as easy as brake lines
fuel pump installed and began to plumb, switch panel for push button start and battery disconnect installed
« Reply #121 on: June 12, 2013, 09:46:21 PM »
Sweet going to be ready for 6/22 shake down
« Reply #122 on: June 12, 2013, 10:57:34 PM »
Noice!
I love bein' wrong sometimes
« Reply #123 on: June 13, 2013, 11:07:23 AM »
Man,where can you get an fittings in this town.need 2 an-8 1 an-10 with barb ends to connect fuel hose
« Reply #124 on: June 13, 2013, 11:32:19 AM »
Power drives or something like that by chips old shop.
« Reply #125 on: June 13, 2013, 11:50:47 AM »
That's awesome!
« Reply #126 on: June 13, 2013, 12:42:25 PM »
Good call on powerdrives had to order a couple of things ,got fuel hose for same price as big box stores
« Reply #127 on: June 13, 2013, 01:31:24 PM »
i had my hydraulic lines made there.  Defiantly wasn't cheap but I set the four required items on the counter and said connect these and it was done lol
« Reply #128 on: June 21, 2013, 06:05:54 PM »
thanks to smike and the free kitchen hauler recycled 10-3 i now have a 15' power cord and can weld anywhere inside and outside my garage.
« Reply #129 on: June 23, 2013, 07:20:57 PM »
started thinking about the wiring and this is the shematic i came up with,will this work,should i run a single wire from the alt to the battery instead?
« Reply #130 on: June 24, 2013, 11:01:05 AM »
With that schematic the engine (and all accessories) will run off the alt after the master disco is killed.
« Reply #131 on: June 24, 2013, 12:31:20 PM »
Yep, that's how the toyota rolls!
« Reply #132 on: June 24, 2013, 01:23:28 PM »
So are you saying I should run a 10 ga. Wire directly from the alt to the battery?
« Reply #133 on: June 24, 2013, 01:41:41 PM »
Thats how I did it.
« Reply #134 on: June 24, 2013, 01:57:05 PM »
If you want the master disco to kill everything while the motor is running that's how you have to do it. or from the alt to the batt side of the kill switch. or better yet get a dual throw kill switch - but that's a topic I've not looked into.
I don't like that the alternator charge wire stays hot even with the kill killed, but it is what it is...
