Author Topic: Troys new Truggy Chassis  (Read 96236 times)
Re: Troys new Truggy Chassis
« Reply #225 on: September 16, 2013, 11:02:34 AM »
i saw majic smoke on crank, that wire was welded to the chassis, thats got to be the prob
find a tac at J&J wile your at it, Matt needs that 14 yoke too!
« Reply #226 on: September 16, 2013, 11:54:26 AM »
Hmm,1st thing I should start with is getting some jy coils and ground the tach wire and see if I can replicate the problem,if it doesn't ill have to work from there.from some quick reading could be dizzy isn't grounded or to many volts to the coil
I would shy away from distructive testing.
« Reply #227 on: September 20, 2013, 05:59:42 PM »
Swapped in a new pigtail with better pin relocation,confirmed my alt is dead and defective replaced at advance works good now,returned overpriced coil to advance and swapped in my fancy msd
« Reply #228 on: September 20, 2013, 06:10:55 PM »
Time to test!!
« Reply #229 on: May 13, 2014, 09:26:28 PM »
added some lb's to this pig and made an actual hood
« Reply #230 on: May 13, 2014, 09:43:27 PM »
Nice!
How much extra weight?
« Reply #231 on: June 16, 2014, 08:51:31 AM »
Troy, do you have a part number for the rear axle brake hoses from caliper to hard line?  Seemed like the perfect length...
« Reply #232 on: June 16, 2014, 05:40:08 PM »
no, i just browsed advances shelves till i found what i wanted
« Reply #233 on: June 24, 2014, 01:50:53 PM »
dont forget fix rear ride height
fix rear pinion angle
fix rear ds yoke / ujoint poped cap
spare tire
« Reply #234 on: June 26, 2014, 10:10:35 PM »
added more shiny metal tonight
« Reply #235 on: June 29, 2014, 09:38:41 PM »
Now that I think of it mark, Smike or Spencer found those hoses on summit and I just cross referenced what advance carried
« Reply #236 on: June 30, 2014, 12:00:28 AM »
harrison had the look up for like 7$ brake hoses
« Reply #237 on: June 30, 2014, 09:40:07 AM »
This thing pissed me off last night. Finished roof cage work then pulled it ahead to install rear solid cover that's been sitting for 6 months, go to start it up to back in and no start, figured I ran it out of gas went and got a couple gallons still no start, an hour later determined but came loose on power dist block and fired right up
« Reply #238 on: July 06, 2014, 06:24:22 PM »
Skinny on this weekend, good 2 days of wheeling little issues like loose cooler line drained Trans to the point forward momentum was stopped, nut off the + side of volt meter fell off and falling wire arched on engine temp sender and melted in half, increase of nitro in front shocks caused the ujoint to self clearance till caps said goodbye, rear hubs are leaky leaky, dirty fuel filter caused some issues
This thing is now known as the Troy machine
« Reply #239 on: July 07, 2014, 07:31:09 PM »
new gauges and some spare parts ordered
talk of big dogs main jambo was talked about
to do list before main jambo:
fix front and rear pinion angles
tree bars
%100 cage work
better tool and part storage
better tire tie down
more oil/tranny pan protection.
missing anything?
