Author Topic: ZJ wonder 5.0  (Read 82992 times)
Re: ZJ wonder 5.0
« Reply #45 on: September 16, 2016, 11:26:17 AM »
trans still same
kind of annoying.
notice there is a hack fix on the TV cable.  going to try and swap that first, and adjust it as per web instructions.
if not, going to try and research governor sol / governor pressure sensor.
if that fails ill pull the trans and replace with spare.  lines weeping anyway.
still need to get inspected.  dropped tank, cant find LARGE evap leak to fix code.  smell gas in rear on multiple occasions upon shut down.  maybe its as simple as a bad gas cap?  hoses and clamps all new and tight.  canister lines look good.
Re: ZJ wonder 5.0
« Reply #46 on: September 16, 2016, 12:09:21 PM »
There's any codes set for the trans?
When it shakes, the rpm bounces? It slips or it felt like it either upshift/downshift or TCC lock/unlock?
Re: ZJ wonder 5.0
« Reply #47 on: September 23, 2016, 08:59:01 AM »
rear hatch struts changed
gas cap changed- still smelled gas this morning
rear dome light bulb changed, still no rear dome or any dome lights ever.
Re: ZJ wonder 5.0
« Reply #48 on: September 23, 2016, 10:13:12 AM »
The light isn't as simple as a factory dome override switch activated or inoperative, is it?
Re: ZJ wonder 5.0
« Reply #49 on: September 23, 2016, 10:26:04 AM »
seems inop
dome rear has a switch to turn on or off doom lights with doors open, i am thinking its a power issue in the hatch since i have never had that light or any of the doom lights come on.  door panel courtesy lights work as they should.
the vic is also gone, but sure if that has anything to do with it.
Re: ZJ wonder 5.0
« Reply #50 on: October 10, 2016, 03:11:15 PM »
hopped on thruway yesterday to go see mom, realized tank was empty, stopped in Batavia to fill.  proceeded to pump 22.5 gallons into the jeep and 1.5 gallons on the ground.
Evap leak probably coming from top of tank somewhere lol.
guess the tank needs to be dropped again and inspected / gasket changed
bah
Re: ZJ wonder 5.0
« Reply #51 on: November 20, 2016, 06:59:10 PM »
rebuilt front CV shaft and installed for winter 4x4
changed sway bar bushings
bipassed whatever is wrong with heater control so has working heat and defrost
dropped tank and changed fuel pump/sending unit.
tank to pump had NO gasket present- gross evap leak identified.
now fuel gage reads empty.  cant win.
Re: ZJ wonder 5.0
« Reply #52 on: November 20, 2016, 07:15:48 PM »
Didn't you just get home
Do laundry and each some football  ;)
Re: ZJ wonder 5.0
« Reply #53 on: November 20, 2016, 10:58:33 PM »
couple laps around Henrietta Tokyo drifting in the snow knocked the sender loose and working.
Re: ZJ wonder 5.0
« Reply #54 on: November 21, 2016, 10:02:12 AM »
foot ball sucks and i need a 4x4 jeep, next is the plow truck.  i am thinking i should have worked on the plow truck sunday instead of the jeep lol
Re: ZJ wonder 5.0
« Reply #55 on: November 21, 2016, 10:11:08 AM »
it'll melt. I'm counting on it.
tractor is in the back yard with the mower deck still on, ready to do the last of the leaves!
Re: ZJ wonder 5.0
« Reply #56 on: November 21, 2016, 10:56:22 AM »
Same boat here...
Re: ZJ wonder 5.0
« Reply #57 on: November 29, 2016, 09:34:09 PM »
ordered a solenoid and pressure sensor kit for transmission.  going to give it a go at fixing trans issue!
Re: ZJ wonder 5.0
« Reply #58 on: December 03, 2016, 11:38:04 AM »
Re: ZJ wonder 5.0
« Reply #59 on: December 03, 2016, 03:14:54 PM »
fail.
3hrs, fluid, 100$ parts.
no change, same.  maybe 1-2 shift 5% better.  still shudders at takeoff
