Author Topic: ZJ wonder 5.0  (Read 82880 times)
Re: ZJ wonder 5.0
« Reply #60 on: January 01, 2017, 09:51:35 AM »
swapped TV cable that was hack fixed, played with it- no change
fluids topped
Re: ZJ wonder 5.0
« Reply #61 on: January 02, 2017, 07:12:10 PM »
noticed coolant was low last week- steam occured last local drive.  heater core hoses rotted out and failed at Tstat housing.
great.
Re: ZJ wonder 5.0
« Reply #62 on: January 03, 2017, 10:55:30 PM »
both heater core hoses replaced.  its really painful to get the advance guy to just sell you 3' of 3/4" and 5/8" ID HTR hose   :(
Re: ZJ wonder 5.0
« Reply #63 on: January 04, 2017, 07:48:32 AM »
reason to not go to advance
Re: ZJ wonder 5.0
« Reply #64 on: January 04, 2017, 07:50:53 AM »
yes i know, sadly.
Re: ZJ wonder 5.0
« Reply #65 on: March 16, 2017, 10:22:58 AM »
played tow truck for Matt last night
my jeep ended up past the truck in the background of this picture before we got him back far enough to pop out of the ditch
Re: ZJ wonder 5.0
« Reply #66 on: March 25, 2017, 06:34:15 PM »
got an oil and filter change today at 239xxx
new cold stumble for a minute or so at idle last couple weeks.  found #1 spark plug to be loose in hole and gave it 3 full turns to snug, neat.
front rugged ridge tie rod shot.  its a 50$ goofy unit bah.
Re: ZJ wonder 5.0
« Reply #67 on: April 01, 2017, 06:32:39 PM »
tie rod installed and aligned.
Re: ZJ wonder 5.0
« Reply #68 on: June 12, 2017, 09:57:48 AM »
got a sticker last week no issues.
seems to have a coolant leak when parked.  must have something to do with pulley squeeking last few months.  probably needs a water pump or something.
Re: ZJ wonder 5.0
« Reply #69 on: August 05, 2017, 10:00:43 PM »
was put out back from leaking coolant last week
new lower hose no fix
2nd time around, had to pull the front apart to change water pump, leaking from block interface or somewhere.
got an AC delete pulley and a good coolant flush.
Back to daily duty.
Re: ZJ wonder 5.0
« Reply #70 on: September 04, 2017, 09:58:18 PM »
2.5"x3.5" rockers burned in tonight.  need more paint to finish second side.
probably gona get a trans swap and put up for sale.  need to thin the fleet
Re: ZJ wonder 5.0
« Reply #71 on: September 06, 2017, 12:01:29 AM »
rockers painted.  bored with this and probably put up for sale.
might do a trans swap- or at least attempt to adjust bands.
Re: ZJ wonder 5.0
« Reply #72 on: November 02, 2017, 09:23:23 AM »
noticed this guy was all over the road at highway speed during the highway cleanup!  have been driving he 49 and CJ a lot more.
Found both ends of the track bar needing service, also found a jam nut loose on one of the drag link ends.
back in business!
Re: ZJ wonder 5.0
« Reply #73 on: November 04, 2017, 08:19:43 PM »
finally just broke apart passenger rear door liner to get the door open.  didnt find anything broken just needed lube.  havent been able to open rear passenger door for at least a year!
almost started on a trans swap today.  meh.
front blinker bulb and fluids topped! ready for winter.
Re: ZJ wonder 5.0
« Reply #74 on: December 10, 2017, 11:00:45 PM »
got an oil change, front lube, and steering wheel alignment today
