Author Topic: ZJ wonder 5.0  (Read 82974 times)
Re: ZJ wonder 5.0
« Reply #75 on: January 01, 2018, 11:43:51 PM »
has a plow half mounted to it tonight haha
Re: ZJ wonder 5.0
« Reply #76 on: January 02, 2018, 08:21:32 AM »
Oh boy...
Re: ZJ wonder 5.0
« Reply #77 on: January 02, 2018, 01:12:18 PM »
How were those SCRs on the way home Sunday? Felt real greasy in the ole dually
Re: ZJ wonder 5.0
« Reply #78 on: January 02, 2018, 01:36:07 PM »
The SCR's were doing work pulling the dead Ford around in the snow yesterday!
Re: ZJ wonder 5.0
« Reply #79 on: January 02, 2018, 01:38:01 PM »
Tway was pretty salty and dry on my drive home.  scrs are great if you stay in the gas,  little sliddy under heavy braking and the rear wants to walk out 90 degrees if no power haha
Re: ZJ wonder 5.0
« Reply #80 on: January 03, 2018, 12:05:19 AM »
first test plowing went well.  trans seems fine with case in low range and doesnt skip at all.  solid unit!
need to fix up the manual til option but power lift with ATV winch is wired.  need to clean up incab but its functional and tested!
Re: ZJ wonder 5.0
« Reply #81 on: January 03, 2018, 08:12:47 AM »
Is this the unit from the shovel?
Re: ZJ wonder 5.0
« Reply #82 on: January 03, 2018, 08:46:37 AM »
Jonboy’s leavings
Re: ZJ wonder 5.0
« Reply #83 on: January 03, 2018, 09:04:08 AM »
ya its a much lighter 7'4" plow than my other two full size plows i have.
its lifted by an ATV winch, and has a manual tilt function.
Made a pin mount and structure out of old 2x2 square buggy links.  Was supprised the jeep only drops about 1/2" when you pick up the plow.
pushes snow fine, maybe needs the springs tightened up for frozen snow now in the lot
Re: ZJ wonder 5.0
« Reply #84 on: January 03, 2018, 09:06:47 AM »
Sweet
Re: ZJ wonder 5.0
« Reply #87 on: January 03, 2018, 04:29:22 PM »
this looks like a reversing relay, with a 3 dollar switch this would be great for me
https://www.amazon.com/dp/B004VAGKZE/ref=psdc_15731411_t1_B00KGICYAA
Re: ZJ wonder 5.0
« Reply #88 on: January 03, 2018, 06:59:09 PM »
I already have one of those on the way.
Re: ZJ wonder 5.0
« Reply #89 on: January 04, 2018, 11:13:13 PM »
plow controls poked through fire wall.
so much nicer to plow with a fuel injected auto with heat and radio!  needed this 6 years ago!
