Author Topic: ZJ wonder 5.0  (Read 73120 times)
Re: ZJ wonder 5.0
« Reply #105 on: October 07, 2019, 08:51:38 AM »
front band adjusted to factory spec, no change.
Re: ZJ wonder 5.0
« Reply #106 on: October 07, 2019, 01:25:57 PM »
key cycle says trans code 12
looks like im checking some tail harness connections and changing a speed sensor
Tranny codes for 1994 OD button LED
11 Engine RPM input
12 Output shaft sensor input
13 Vehicle speed input
14 Governor pressure sensor input
15 Throttle position sensor input
16 Transmission fluid temperature input
17 Overdrive override (control) switch input
18 System voltage
19 Internal fault in module
21 Governor pressure solenoid output
22 Overdrive solenoid output
23 Converter clutch solenoid output
24 Overdrive override (control switch) lamp output
25 Internal fault in module
26 Governor pressure sensor offset drift
55 End of code transmission
Re: ZJ wonder 5.0
« Reply #107 on: October 10, 2019, 10:58:30 AM »
new output speed sensor installed.  no change
Re: ZJ wonder 5.0
« Reply #108 on: October 10, 2019, 11:01:54 AM »
could it be the transmission itself is fucked and a new rebuilt tranny fixes your troubles?
Re: ZJ wonder 5.0
« Reply #109 on: October 10, 2019, 11:45:11 AM »
ill pull the pan and adjust the rear band- that's the last thing i can do, then im done again trying to fix it.
not worth pulling and swapping without a catastrophic failure, especially with 3x the work involved with the long arm kit in the way.  it drives fine for me, and even plows snow fine if you are not a moron.
Re: ZJ wonder 5.0
« Reply #110 on: October 10, 2019, 05:39:19 PM »
Rear band has nothing to do with your symptom. It’s only used when shifted into R or L
Re: ZJ wonder 5.0
« Reply #111 on: October 10, 2019, 06:42:52 PM »
That doesn’t make sense. Shifter position doesn’t impact what the trans does in 1st gear, whether in low/1/2/D
I don’t know what band is which but 1 and R typically share the lowest gear
Re: ZJ wonder 5.0
« Reply #112 on: October 10, 2019, 08:53:09 PM »
no L selection in this application.  12DNR
shifts and acts much better when manually shifted.  still has the issue though to some extent.
Re: ZJ wonder 5.0
« Reply #113 on: October 11, 2019, 02:53:07 PM »
Sorry, L and 1 means same thing. Service manual call 1st gear selection as “low”, so...
The rear band sparsely get used as it only engages when manually shifted into 1st/L or R. Pretty much why it’s buried inside as it hardly ever need adjusting for most people, or why you see a lot of old Ram plow trucks for sale saying “no reverse” from shifting between D and R all night long.
Trans get its first gear different way when shifter is in “D”
« Last Edit: October 11, 2019, 02:58:03 PM by TrailTamer »
Re: ZJ wonder 5.0
« Reply #114 on: October 11, 2019, 04:20:45 PM »
Crazy.
Automagic
Re: ZJ wonder 5.0
« Reply #115 on: October 11, 2019, 04:21:06 PM »
Crazy.
Automagic
Re: ZJ wonder 5.0
« Reply #116 on: October 11, 2019, 04:21:15 PM »
Crazy.
Automagic
Re: ZJ wonder 5.0
« Reply #117 on: October 11, 2019, 04:24:49 PM »
Crazy.
Automagic
Re: ZJ wonder 5.0
« Reply #118 on: October 11, 2019, 04:31:09 PM »
Crazy.
Automagic
Re: ZJ wonder 5.0
« Reply #119 on: October 11, 2019, 10:32:44 PM »
Insanity
