Author Topic: ZJ wonder 5.0  (Read 82874 times)
Re: ZJ wonder 5.0
« Reply #135 on: January 17, 2022, 05:33:47 PM »
pushed a lot of snow this morning, might need to put some drive SCRs on the front for winter instead of steer cuts, but other wise she hawgs pretty good with the new to it transmission.
it does want to stall now though when going from revers to drive or drive to reverse.  need to google that and see if its something that can be fixed / adjusted.
Re: ZJ wonder 5.0
« Reply #136 on: January 30, 2022, 03:00:03 PM »
bAH, rear D35 gear set gave up from heavy plowing.  i thought it was the front drive shaft talking, but its the rear set
looking for a used D35 3.54 get set.
Re: ZJ wonder 5.0
« Reply #137 on: January 30, 2022, 03:45:12 PM »
3.54 gears are blown.  i started dissasembly thinking it was an 8,25 which i had a used set in my pile- realized its a D35 bah.
i have a YJ 3.07 gear set that i think is the same and could pull the front drive shaft
i kinda need the jeep this week.  RAM is blue sticker, needs brakes and tires and inspection done bah
I guess if i slap in the 3.07s in ill confirm YJ sets are same to a ZJ D35, and either order a 50$ used gear set off ebay,  I do have a used set of 4.56 gears for the front low pinion D30, so i could commit a sin and order 4.56 gears for the D35 lol bah
Re: ZJ wonder 5.0
« Reply #138 on: January 30, 2022, 04:08:21 PM »
Stickers are such bullshit
Re: ZJ wonder 5.0
« Reply #139 on: January 30, 2022, 04:12:21 PM »
i still dont have a good place that will take the RAM either.  its annoying.
Re: ZJ wonder 5.0
« Reply #140 on: January 30, 2022, 04:19:47 PM »
best i can tell says all D35 gear sets are same across all jeep yj XJ MJ ZJ WJ  with maybe a different pinion seal and spider gear differences of course.
amazon has 139$ 4.56 D35 gear sets and i already have the 3.54 and up carrier.  have mismatched stuff for the front in stock.  i guess ill go that way, but to get it off the lift it will get 3.07s slapped in it.  its already apart and C clip, o well.
ill stop rambling about this misfortune now
Re: ZJ wonder 5.0
« Reply #141 on: January 30, 2022, 05:51:36 PM »
Lol
Re: ZJ wonder 5.0
« Reply #142 on: January 31, 2022, 12:08:07 PM »
I have the D35 3.54 ring and pinion from my Comanche sitting in a box at home. 190k or so on them. If you can confirm they'll fit, I can ship to you. It's an early non c-clip axle, not sure what other differences may exist.
Bummer, I was just home last week
Re: ZJ wonder 5.0
« Reply #143 on: January 31, 2022, 03:05:02 PM »
45$ on ebay got me a used 3.54 set headed my way, thanks
Re: ZJ wonder 5.0
« Reply #144 on: February 03, 2022, 07:05:15 PM »
still plows snow with a few pinion teeth missing  :o
once the transmission warms up it shudders and stalls/locks up in reverse- i guess this trans has always been like this since installed i just didnt notice till plowing.  annoying.
i think its time for a new wonder this year sometime.
Re: ZJ wonder 5.0
« Reply #145 on: February 06, 2022, 03:07:06 PM »
ebay rear gear set installed, fixed front squirters too!
carchameleon
Re: ZJ wonder 5.0
« Reply #146 on: February 11, 2022, 08:56:08 PM »
I know its not around the corner, but have you tried Scotty's?
talk to pauly and tell him you know arie and me
Re: ZJ wonder 5.0
« Reply #147 on: February 24, 2022, 09:43:17 AM »
more 42RE sighs.
trans performs 100% cold, but very shortly once it warms up begins to want to "stay locked up" when coming to a stop (occasionally), and after a short drive will lock and stall engine if you shift to reverse (100% of time warm) from park/neutral.  like if you pull into a parking spot at a store, it better be a pull through...
my research shows:
could be issue with brake switch not giving signal to unlock TC
bad TCC solonoid
bad TC (less than 500miles on new TC when trans installed)
not really anything i can find that sounds like a smoking gun
annoying!
« Last Edit: February 24, 2022, 02:08:38 PM by M4wdFab »
Re: ZJ wonder 5.0
« Reply #148 on: February 24, 2022, 02:12:37 PM »
i have had this transmission out twice now, and i have fixed or bipassed cooler lines at least 2 other times.
how is it that i did not realized until today there is a check valve in one of the cooler lines?
i was flushing out the cooler with air and noticed it only going one way.  pulled the pan and valve body today and did the HD upgrade kit.  filter and magnet was packed with fines but not chunks or hard parts in the pan.
if this doesn't change it, im guessing the new torque converter has failed or the lockup solenoid is intermittently bad.
Re: ZJ wonder 5.0
« Reply #149 on: February 24, 2022, 03:11:26 PM »
and zero change with the 42RE fix kit, filter, fluids.  another 150$ down the drain.
i guess next will be a brake light switch and then a lockup solenoid- but its probably better to just get another jeep.  really sad this TN truck still has no exterior rust and isnt falling apart.
