Author Topic: MMTR Brolite  (Read 111009 times)
Re: MMTR Brolite
« Reply #405 on: January 15, 2020, 06:09:48 PM »
Still out for delivery. Zero chance it’s arriving tonight.
Re: MMTR Brolite
« Reply #406 on: January 15, 2020, 06:10:11 PM »
And there’s a lost amazon driving in front of my house right now. Hahaha
Re: MMTR Brolite
« Reply #407 on: January 15, 2020, 06:30:30 PM »
Sweet multi post.
When your cheap braided lobe and AN fitting set comes with o-rings for each AN fitting, you know it’s quality.
Re: MMTR Brolite
« Reply #408 on: January 15, 2020, 11:29:21 PM »
My jump pack doesn’t have enough ass to start the bro on its own. Charging the shot battery that was in it last season. Missed one fitting. Will be running with no power steering and no belt. Fitting due Friday. Assemble and fill. Done. Assuming no leaks.
Hopefully the belt hanging off it is right.
MMTR Brolite
« Reply #409 on: July 17, 2020, 01:08:41 PM »
Belt hanging off it was wrong. I have a lot of belts that are wrong. Some of these may fit smikes or Matt’s engines?
Did not achieve perfection. Pulley align must be slightly off, brand new belt walks 2 ribs at high rpm
« Last Edit: July 17, 2020, 01:10:15 PM by mr.mindless »
Re: MMTR Brolite
« Reply #410 on: July 17, 2020, 01:53:44 PM »
not sure whats on my car.  dont think i have ever bought one.  enough new complete engines with good belts :(
Re: MMTR Brolite
« Reply #411 on: July 17, 2020, 04:58:36 PM »
After I made the adjustment I thought it would need it walked 3 ribs at idle.
Need to take upper rad hose off to get good eye on things. Probably just need to pull the pulley off 0.25”
Easy to pull off that upper rad hose since I failed at getting the rad damage to seal up. I’ll just throw some Barr’s Leaks in it if I get the steering good and it’ll be ready to run.
I cut, twisted, and flattened the 4 bad tubes after failing at soldering them a few times.
I need a tig. Probably could have touched the 5 bad spots and been done. Or blown some big, meaningful holes in it.
Re: MMTR Brolite
« Reply #412 on: July 17, 2020, 09:57:07 PM »
 Backed off the pulley this far (sample pump, assumed same shaft length since they seem to be standard). Seems maybe ok! Load center is not beyond snout of shaft but is damn close.
That depth is exactly as thick as the mounting ears on the bracket.
If this ruins the pulley or shaft, I should be able to make an offset pattern face mounting plate. Otherwise just make an entire new mounting bracket. Needs to incorporate an idler pulley that mounts on a different plane, so that’s annoying.
Re: MMTR Brolite
« Reply #413 on: July 18, 2020, 05:53:39 PM »
#fail
Re: MMTR Brolite
« Reply #414 on: July 18, 2020, 05:56:23 PM »
Absolute max replacement width 24”
Mounting terribleness will go away.
Re: MMTR Brolite
« Reply #415 on: December 19, 2020, 11:01:25 PM »
Should have new radiator in tomorrow, and a second truck OUT of the shop. Shame I don’t have straight fenders to put on it, would be nice to redo the whole front clip, but that can wait for never. Or if anyone uses these things again.
Bottom is lower than old radiator was. Channel is about the right size with isolator padding and should hopefully protect from any from-the-bottom damage. May add a tie or three to the bumper for good measure on that front.
Going from two fans to one due to smaller radiator surface. I’m certain that’ll still be plenty adequate. I think they’re 12”
I still work like a heathen. Too much done on the floor. Still not putting things in sane places even with plenty of room. Not having “away” places yet to put things. Decades of habits from shit workspace to break. It’s embarrassing. How long will that take?!
I sure do love that portaband no matter what, though.
Re: MMTR Brolite
« Reply #416 on: December 19, 2020, 11:21:48 PM »
i was thinking about dragging up my spare truck and just scavenging good parts from it to scrap the chassis
its getting beat stored for so long with out care.
Re: MMTR Brolite
« Reply #417 on: December 20, 2020, 01:03:57 AM »
My crooked chassis makes me grumpy. Stupid mistake on that frame repair. Oh well
Re: MMTR Brolite
« Reply #418 on: December 27, 2020, 10:05:44 PM »
Didn’t touch rear fenders but it’s race ready. Radiator is done and full, battery box is on and hold down is tight.
Re: MMTR Brolite
« Reply #419 on: May 16, 2021, 08:59:49 AM »
Radiator got mud plugged and I overheated.
Found out from Will that after pulling my cluster I would not be charging. Battery went dead after second heat. Got a push start and crossed the right two wires to fix that.
Great shakedown. I need to wire up a mud muncher hookup in this one, badly!
