Author Topic: MMTR Brolite  (Read 110970 times)
MMTR Brolite
« Reply #435 on: July 03, 2021, 10:24:23 PM »
No luck in Marketplace hunting. I think rangers as late as 2009 will have when I’m after so maybe j&j… probably end up with a 31sp and won’t be able to use my spool or something.
I’ll have to see if I can repair the one I ripped off. It hadn’t been rotted out so maybe. I haven’t really looked at it.
Humbug.
Stupid move.
Re: MMTR Brolite
« Reply #436 on: July 08, 2021, 10:03:47 PM »
doesn't look like I put parts info for my steering in back at post 400
this is the AN to steering box fitting https://www.amazon.com/gp/product/B000CPAS1E/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
this is the TC pump 90? to return fitting for a remote resi https://www.lsxconcepts.com/products/saginaw-type-ii-tc-series-90-degree-power-steering-return-fitting
and this is the shit -6 AN kit that I have a leaking fitting from that I can't actually recommend. https://www.amazon.com/gp/product/B07XXYBNWB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Re: MMTR Brolite
« Reply #437 on: July 21, 2021, 08:46:57 PM »
Didn’t notice the condition of the 8.8 mini spool when I took the axle apart. All chips were in the diff so all damage is new from my use.
Musta been real cheap shit. Was new out of box with the axle.
Re: MMTR Brolite
« Reply #438 on: July 27, 2021, 07:22:18 PM »
Re: MMTR Brolite
« Reply #439 on: July 28, 2021, 12:00:44 AM »
Just needs fluids and tires.
Re: MMTR Brolite
« Reply #440 on: July 31, 2021, 07:59:37 PM »
turns out it was a good thing for me that we called off the race. moved this today and it dumped all sorts of coolant and power steering fluid. Appears I didn't get a good seal on the braided hose when I replaced the bad AN fitting, and I may have to look for a crack in the radiator inlet. That is definitely the source, and the hose feels good and I cranked down the clamp. not sure wtf is going on there yet.
Re: MMTR Brolite
« Reply #441 on: July 31, 2021, 08:00:22 PM »
bah!
Re: MMTR Brolite
« Reply #442 on: July 31, 2021, 08:21:15 PM »
After the ride it took, at least the brakes feel great and it drives straight!
Re: MMTR Brolite
« Reply #443 on: September 10, 2021, 02:49:54 PM »
Coolant leak was power steering pully kissing rad hose. Had a couple hairline slices.
Shortened rad inlet and trimmed hose.
Redid ps pressure hose. Hopefully fixed?
Re: MMTR Brolite
« Reply #444 on: September 12, 2021, 12:03:20 PM »
Coolant leak duplicated.
Also apparently under-spec’d my trans mount.
Re: MMTR Brolite
« Reply #445 on: September 26, 2021, 10:45:45 PM »
Trans mount rebuilt. Tons of clearance to rad hose now. Expect that issue won’t triplicate but will find out Saturday!
Re: MMTR Brolite
« Reply #446 on: October 13, 2021, 01:11:41 PM »
so, discovered today looking for 8.8 bearings /seals National and timkin make a fix it bearing with integrated seal that may have worked in the above axle failure that destroyed the seal bore.
https://www.rockauto.com/en/moreinfo.php?pk=1119537&cc=1438302&pt=1672&jsn=538
20$ seal and hammer the backing plate might have been good enough for a bro!
Re: MMTR Brolite
« Reply #447 on: October 13, 2021, 03:59:15 PM »
I had enough of a circle left there that I RTV'd and sent it. that's a good option if it starts leaking or kicks the seal out though!
backing plate was ripped clean off, didn't have an option on that bit. still annoyed I had to actually build it and couldn't just spend $30 but it seemed to work out. more payoff on the plasma cutter and Ryan's stack of box covers from a decade ago
Re: MMTR Brolite
« Reply #448 on: October 13, 2021, 04:29:56 PM »
I noticed that, Those pieces are older than my kids, hahaha
Re: MMTR Brolite
« Reply #449 on: December 29, 2021, 12:34:18 PM »
Long term rear tire leak found. Valve stem. Not Schraeder but stem to wheel. Haven’t seen that on an aluminum, but it was a sharp edge that shaved down the stem just a tiny bit.
