Author Topic: MMTR Brolite  (Read 111081 times)
Re: MMTR Brolite
« Reply #375 on: April 26, 2019, 11:39:42 AM »
lol
Re: MMTR Brolite
« Reply #376 on: April 26, 2019, 11:42:21 AM »
Shoooooort laps.
Pretty sure these are interference too.
Not good enough for being alone on the track when it munches the engine and I have to get pushed off, then don’t have a winch to get it in the truck, 6 hours from home.
Would be a good acid test for Sarah
This. Is. Racing.
Re: MMTR Brolite
« Reply #377 on: April 26, 2019, 12:42:55 PM »
God bless Ingersol-Rand
Re: MMTR Brolite
« Reply #378 on: April 26, 2019, 01:04:08 PM »
Crank was keeping the belt from walking off.
Puller just cleared radiator. Should pull off with a tap. It’s keyed and straight fit.
Re: MMTR Brolite
« Reply #379 on: April 26, 2019, 03:51:18 PM »
That feeling when every attempt is resulting in being a half tooth off. How even?
Probably NOT interference BTW. Fully rotated cam with crank at or near its timing mark.
Re: MMTR Brolite
« Reply #380 on: April 26, 2019, 05:08:49 PM »
Done. Small coolant leak returned after reassembling everything and purring the belt on.
Water pump and water neck were new late last year due to same issue. It’s probably that stupid plastic water neck to pump o ring seal. Humbug.
Re: MMTR Brolite
« Reply #381 on: April 26, 2019, 06:09:30 PM »
moved mine to the new barn today to empty out my enclosed.  didnt even air the tire up, fired right up and go.  surprising!
Re: MMTR Brolite
« Reply #382 on: April 26, 2019, 07:08:01 PM »
I had to jump mine. Think the bad alt wasn’t charging well. Hasn’t hesitated to start since even with 4-6 starts without a belt.
Tied down, hood closed, ready to rock. Ish.
Thanks to any-Way for the support! :)
Re: MMTR Brolite
« Reply #383 on: June 22, 2019, 07:28:01 PM »
#portapower
I don’t think I’ll straighten it here but I could. Just in case need of heat or welder that i don’t have here. No tire contact.
Took the wind out of the other driver :(
Shouldn’t have. But did. Might post a video clip later if I feel like pulling it.  I definitely have it.
Re: MMTR Brolite
« Reply #384 on: June 23, 2019, 09:50:06 PM »
Adjusted the core support right into the radiator today. Patched up to run second heat and it hardly even leaked on the way home. Gooder as newish.
Re: MMTR Brolite
« Reply #385 on: June 24, 2019, 07:38:44 PM »
Ignorably dry. What a dismotivation!
Re: MMTR Brolite
« Reply #386 on: June 27, 2019, 10:46:39 AM »
Probably because mud is holding it together  haha
Re: MMTR Brolite
« Reply #387 on: September 18, 2019, 04:08:35 PM »
Should probably move that plug next to where the tire rubs
Re: MMTR Brolite
« Reply #388 on: September 27, 2019, 04:05:08 PM »
Driver side axle seal is out in that 8.8. Coolant was low so temp fix on rad isn’t permanent.
See if I can stick the 571 radiator in or not since I have a spare of that. If not it’ll be something skinny enough to go between the uprights. Or I park it for a parts truck and race Kim’s for 1500.
Or I give up since nobody else races them anymore
Re: MMTR Brolite
« Reply #389 on: September 27, 2019, 06:06:49 PM »
my truck is ready minus some air in a few tires
