Author Topic: 571  (Read 264728 times)
Re: 571
« Reply #810 on: June 03, 2016, 07:25:08 AM »
weld cracks to the cast common there, been fixed a few times.  the cracks going upward if thats what they are look interesting
Re: 571
« Reply #811 on: June 03, 2016, 08:21:37 AM »
Yup. Forward a bit too. Nothing on the front side or that I could see on the bottom
Re: 571
« Reply #812 on: June 10, 2016, 09:26:17 AM »
Wheels had been backordered. Sunfire rec'd theirs yesterday in Indiana, so mine could be today, or Monday.
USA-made stubs and CTMs will be here Saturday from East Coast Gear Supply. I was going to go with Nitro joints (they state plainly that their USA-made stubs _will_ break a Spicer joint, no problem, and will only warrant them once for a joint break. Upgraded joints = lifetime warranty) but they actually called me suggesting I go with Yukon Superjoints or CTMs. The Nitros have had issues with galling, and new caps costs as much as a whole joint ($80/cap!). Chose CTMs over Superjoints after seeing Matt's issues with play and squeaking, and since they're supposedly more durable to daily driving duty that we do in long races.
Re: 571
« Reply #813 on: June 10, 2016, 11:42:15 AM »
thos yukon shafts have been through a whole lot of abuse!
Re: 571
« Reply #814 on: June 10, 2016, 12:19:50 PM »
true story!
inners will be the new weak point. assuming the gearset lives a while.
Re: 571
« Reply #815 on: June 10, 2016, 01:05:26 PM »
i dont think i had ever blew a chromo inner on that car- a couple of stubs and a couple delco joints, but never a spicer joint either
Re: 571
« Reply #816 on: July 01, 2016, 09:54:43 AM »
crammed all prep into one night. Meaning not much prep. put a passenger seat in, and broke a front shifter putting it on the trailer, so had to clean that up and re-weld. weird it lasted as long as it did and then failed now (poor weld, lasted all the way from redoing the floor and swapping in the new trans way back when)
other CTM and ECGS stub shaft are in the tool bag. hopefully the caliper keeper bolt is happy (bent wheel sheared the head off the left side unit. right side not evaluated)
need to redo my buggy tools since getting the tool cart in the garage, and evaluate what really needs to go with. Random assortment now.
only one spare tire going with, others not reassembled yet.
I checked - had 37 hours on campus so far this week when I got home. It really feels like a lot more than that.
Re: 571
« Reply #817 on: July 01, 2016, 10:42:17 AM »
i am on track to see you around 4:15
Re: 571
« Reply #818 on: July 01, 2016, 10:44:30 AM »
I'm gonna try to get to smikes around 4 that will give me time to unload and disconnect and be ready when you guys roll in
Re: 571
« Reply #819 on: July 01, 2016, 12:01:57 PM »
see you guys then!
still planning to be done w work at 3. most of my gear is sorted, just need to grab clothes and not much else and throw all of it at the car.
Re: 571
« Reply #820 on: July 01, 2016, 12:59:26 PM »
Enjoy!
Re: 571
« Reply #821 on: July 02, 2016, 07:16:58 PM »
I think I lost an exhaust valve seal. Suddenly started blowing way more smoke with no other symptoms. Collector gasket on driver side is wet with raw (well, cooked...) oil
Schieße.
Trans also running hot crawling. I forgot what rec wheeling is like. Feels like I’m in high range with I 2:1 doing technical stuff and hard climbs.
Tried and failed to stuff it through the CV notch.
No other issues. Ride seems great. Seems stable not that I’ve cornered hard.
Re: 571
« Reply #822 on: July 03, 2016, 01:00:20 PM »
Radiator pinhole now too. Booo
Re: 571
« Reply #823 on: July 04, 2016, 04:45:58 PM »
- hot trans even after adding another 2qt. It idled empty in park, and tried and failed to go one when empty. Enough to do damage? Fluid in it now is burned. I saw 270+ when crawling and it would not cool quickly. Still held gears fine.
- radiator pinhole in 2nd to bottom row. How best to mount in current position?
- I think I'm still touching one lower front shock eye with the steering arm
- running like shit and blowing blue smoke. Minimal oil usage for the amount of smoke. Need to do compression test. If it has solid compression I need to get a passenger o2 on it, maybe a thermostat to stay in closed loop, and get a scan tool on it to see what else it thinks is wrong.
Re: 571
« Reply #824 on: July 04, 2016, 08:13:57 PM »
there are five 6.0s on CL right now from 700-1400 in various configurations. No 5.3, at least that include "5.3" in the ad - that seems a useful way to sell one.
didn't dig through cheap trucks.
compression test first....
