Author Topic: 571  (Read 222339 times)
Re: 571
« Reply #780 on: April 27, 2016, 11:49:26 AM »
Thought I needed a quick battery terminal cleaning. Ended up disassembling and cleaning both posts, hot post, then still chasing voltage drops of 2 or 10 Volts. All well as soon as I r&r main shutoff. Bringing the spare but I think it may have had some dirt between the contacts that I jarred. Can't get it to fail again.
Effective and enjoyable 2hr start to today's festivities!
Re: 571
« Reply #781 on: April 27, 2016, 01:55:10 PM »
Arrival.
Bling fuckin BLING.
Also: 5/8 with reducing misalignment. HOURS saved! Whew!
CJ
Re: 571
« Reply #782 on: April 27, 2016, 07:11:57 PM »
Post that up on FB and tag those guys  8)
Re: 571
« Reply #783 on: April 28, 2016, 09:12:44 AM »
Long day ahead today.
Finish weld remote resi mounts. Configuring and placing those took a while!
Frame side front link mounts
Rear swaybar mounts, arms, links
Rear bump cans. Plan finalized.
Front Pinion seal
Oil change
Steering bolts. Leaving tie rods for now. Hope to prerun both configurations and see how they feel.
Assemble springs on shocks. ADS sliders are really embarassing. Fix arrives today.
Modify hood to clear shock resis
Re: 571
« Reply #784 on: May 02, 2016, 04:52:14 PM »
Must Do:
front gearset (?)
fix rear suckdown
new master kill switch
Want Do:
front driveshaft
front lower links
traction tread on brake pedal
heel cup for accelerator
rear upper links delete bushings (use front upper 1" heims in existing links)
hood
heavier swaybar?
Maybe next:
fresh tins
dzues fasteners
rear lower link bushing delete
more siren wiring
other rewiring
interior tin work
Re: 571
« Reply #785 on: May 02, 2016, 05:15:49 PM »
Lots of swaybars up right now. several 2", a 1.5, several between 1 3/16 and 1 1/4...
should hit the RTI ramp with/without to see what difference it makes, and to check front spring cup clearance.
Re: 571
« Reply #786 on: May 02, 2016, 05:35:33 PM »
those ball pushy things timmy posted on FB look way better than dzeuce
front gear set- check your spool is a 4.10 and down, or 4.56 and up like ours that uses:
http://www.summitracing.com/parts/mgr-d60-538
they list an SVL gear set for 165 i had not tried.  also motive gear avail though advance with 30% coupon
master disconnect- i believe this is the unit in our 3 cars:
http://www.summitracing.com/parts/mor-74102/overview/
front 2" 1350 slip yoke
http://www.dennysdriveshaft.com/p4505_dana_spicer_3_3_2591kx_slip_yoke_1350_series_.html
stub
http://www.dennysdriveshaft.com/p4504_dana_spicer_2_40_1701_spline_fits_2.0_inch_.120_wall_tubing_.html
1350 joints http://www.dennysdriveshaft.com/p4507_dana_spicer_5_178x_greaseable_u_joint_1350_series_.html
if you looking to rebuild all the front shaft, get rid of that superduty flange and CV just go to 2" bearing 4 bolt bearing / yokes:
http://www.ebay.com/itm/2-4-Bolt-Flange-Bearing-UCF210-32-UCF210-/291490103045?hash=item43de29ff05:g:xtwAAOSwqu9VFDdA
(3) http://www.dennysdriveshaft.com/p2153_neapco_n3r_28_1757__weld_yoke_gm_3r_series_to_fit_2_inch_.12.html
matts front shafts are 2" .120 wall DOM with 1.75" .250 wall DOM slid inside
could also keep / replace the saddle bearing, add a safty strap like my car has.
Re: 571
« Reply #787 on: May 02, 2016, 05:42:15 PM »
Deserves safety strap. don't recall if it's currently a good fit or a poor fit up top above the flange. I shouldn't need to buy any shaft parts, have a wide selection of good parts including brand new never used 1350 stuff from the dakota rear shaft. it's just the bottom slip I'm worried about. it's so floppy!
Re: 571
« Reply #788 on: May 02, 2016, 05:48:09 PM »
I run the deep gear spool STR-D1548
the USA Standard gears I bought last time current pricing is $242 from Summit and ship end of May. Your link for Motive are $210 and ship today. Even better if there's a good coupon somewhere.
I will pull a cover and confirm before ordering.
Re: 571
« Reply #789 on: May 02, 2016, 05:57:37 PM »
interested. can't find looking through his page though. any idea how long ago? I scrolled back into Easter Jeep stuff and didn't see anything
Re: 571
« Reply #790 on: May 02, 2016, 06:04:00 PM »
maybe it wasnt Timmy
Quik Latch Distribution
Re: 571
« Reply #791 on: May 02, 2016, 06:09:39 PM »
I’ve spent A LOT of money on this thing in the last couple months but $27ea is too much for body panel fasteners.
Re: 571
« Reply #792 on: May 04, 2016, 06:04:11 PM »
These are amazing.
Pricy but worth it for the right application.
Thanks for sharing Smike
Re: 571
« Reply #793 on: May 05, 2016, 02:19:56 PM »
Brian just returned my call from last week - he suggests 200-225psi fully extended for racing. Can go down to 150psi at ride height for trail riding.
I know I set them at 200, don’t recall for certain if that was at full extension or not.
Re: 571
« Reply #794 on: May 05, 2016, 03:50:58 PM »
i believe Wayne recommendation was 250psi for shit dirty oil, 200psi in new foxs
