Author Topic: 571  (Read 264719 times)
Re: 571
« Reply #795 on: May 17, 2016, 01:53:40 PM »
 Note to self:
frame width 30”
Re: 571
« Reply #796 on: May 18, 2016, 02:44:17 PM »
Re: 571
« Reply #797 on: May 18, 2016, 03:20:49 PM »
ooof coast and drive wear marks look way out
pinion looks too deep and too much backlash
Re: 571
« Reply #798 on: May 18, 2016, 03:24:12 PM »
100% setup bearings in there too. What the fuck did I do?!
Dont have the bearings I think I did either.
So: looking for a install kit. F.
Re: 571
« Reply #799 on: May 18, 2016, 04:39:16 PM »
Install kit obtained; credit: Arie/ NuWay. Awesome!
Waiting on some medium speed foods (certainly not fast at this point) up by Carter now. Probably work through the meeting and maybe get the gears wrapped up.
Flatted a trailer tire on a curb cut for a drain grate outside Spencer’s shop. Awesome.
Sounded like a gunshot. Half surprised I didnt see rpd cruise by after.
Re: 571
« Reply #800 on: May 18, 2016, 06:13:41 PM »
ya 19.5's sound awesome when they blow.  bummer.
Re: 571
« Reply #801 on: May 18, 2016, 06:22:10 PM »
15” LR E thankfully. At least a cheaper F up.
Ring gear mounted up. Time for details. Enjoy the meeting! Kim’s cage painting on the bro :)
Re: 571
« Reply #802 on: May 24, 2016, 02:26:27 PM »
2 replacement wheels and 2 more innerairlocks ordered so I'll have 6 & 6 now.
tires are NOT yet flat.
I expect the wheels to crack if we try to straighten them. I think the only way worth trying would be with some constructed dies in a large shop press. Thoughts? or just scrap em?
Re: 571
« Reply #803 on: May 24, 2016, 02:27:47 PM »
i havent tried heat yet
bottle jack with plates no good, hammer no good
Re: 571
« Reply #804 on: May 24, 2016, 02:30:17 PM »
I was thinking about heat as I typed that. First thought is it seems like that would be bad.
how big a bottle jack? I'd figure a 20t inside the wheel ought to be able to stretch it right out and rip it apart. That would be easier than dies in a shop press
Re: 571
« Reply #805 on: May 24, 2016, 02:33:14 PM »
not sure how short my 20t air-over goes, but a curved section with a flat base for the base of the jack to sit on and spread across 20-30% of the wheel, and a rounded dolly for the business end should get some motion in the right spots. Doesn't have to be perfect, just good enough. Not much to lose other than fingers
Re: 571
« Reply #806 on: May 24, 2016, 02:35:21 PM »
i have at least one wheel thats punched though to try methods on- it may have a tire still on it.  not sure if the other wheel is around
Re: 571
« Reply #807 on: May 31, 2016, 10:46:24 AM »
new wheels have not shipped. fail on me for just going back to previous vendor and pushing the button instead of checking stock/fulfillment date.
will swap good innerairlock'd tires to front, run my 2 non-locked spares in the rear. Spare tire will be a tubed shredded tire on an H2. Boo.
didn't touch this thing all weekend. Will take care of tires and trim bump pads, and probably move front lower shock mounts inboard about 0.200" to better clear highsteer arms.
Re: 571
« Reply #808 on: June 02, 2016, 09:44:12 AM »
Wheels shipped yesterday. No tracking info supplied.
Tires swapped on the right, not yet on the left. Front shock tabs moved in on right, removed only so far on left. Need to fix suck down and swap left tires, thats about it for tonight. might try to do PA wiring but i kinda doubt it.
Re: 571
« Reply #809 on: June 03, 2016, 12:23:39 AM »
Interesting find:
