Author Topic: 571  (Read 265389 times)
Re: 571
« Reply #435 on: January 13, 2015, 11:41:47 PM »
anyone know this connector? Superwinch solenoid. Planning to direct wire to dash switch, would like to not just cut it off the factory relays if I can get another...
It's the female end I need.
Re: 571
« Reply #436 on: January 13, 2015, 11:54:49 PM »
let me take a look.  looks familiar.  might need to remove the polorize tab
looks just like a TPS conector
Re: 571
« Reply #437 on: January 14, 2015, 07:31:03 AM »
almost 100% available in Standard..
look at super winch website
Re: 571
« Reply #438 on: January 20, 2015, 11:38:49 PM »
What the fuck was I thinking getting min install kits?
Fuck my garage, too. Hard
Re: 571
« Reply #439 on: January 20, 2015, 11:43:09 PM »
last minute motor sports!
if its rolling bring it over after Thursday night we will have the third bay cleaned out.  i think both are cars are done with the lift also.
sorry i should have offered earlier and planned better.
Re: 571
« Reply #440 on: January 21, 2015, 01:17:36 AM »
Confirmed front was all on setup bearings. Will stay that way for Cali most likely. Goal was to get both ends done tonight. Left work at 7p yet again, just got front to first pattern check. Not checking; going to bed.
Took every shim I had to make the carrier tight. Housing is likely a bit spread with as loose as the stock carrier was with a reasonable number of shims. God I want dropout thirds.
Re: 571
« Reply #441 on: January 21, 2015, 08:20:53 AM »
throw the new pinion in as the old was depth wise and set the preload.  get the carrier in with preload and backlash.  put the cover on.
matts spool too .060 on each side to get some preload for a start.  i doubt that housing is spread, or it would be broken.
Re: 571
« Reply #442 on: January 21, 2015, 02:36:12 PM »
I have arms.
Re: 571
« Reply #443 on: January 21, 2015, 03:26:05 PM »
not sure how many turns lock to lock you are now,
but i reduced my radius by about 3/8" when i went to artecs and got my steering from 2.3 turns to just a little less than 2 i believe.
Re: 571
« Reply #444 on: January 21, 2015, 05:15:33 PM »
ooh, good call. I'd like to be a little less, that's easier than a quickener. I'll have to do some playing.
though that car already doesn't have enough steering stop in it for the axle joint clearance.
Re: 571
« Reply #445 on: January 21, 2015, 05:17:37 PM »
the solid knuckles have bosses that contact the C
if all the bolts are gone and its just boss on C, you only travel about 30-35 degrees steering
mine are beat in enough on the knuckle i get about 42 degrees
Re: 571
« Reply #446 on: January 21, 2015, 05:21:22 PM »
I think these are probably 35, but the yokes are probably good for 32. They fight. It'll break ujoints eventually. I'm not changing them right now since they look and feel good. I'll regret that i've done nothing to limit the knuckles or ram the first time that's actually a problem.
Re: 571
« Reply #447 on: January 21, 2015, 05:30:17 PM »
weld a 3/8 nut to the C or knuckle, done
Re: 571
« Reply #448 on: January 22, 2015, 11:29:14 PM »
Mike we missed you tonight!
Re: 571
« Reply #449 on: January 23, 2015, 01:10:05 AM »
At work till 9  not much accomplished. Hate this shit...
Hope the next the days are stupendous
