Author Topic: 571  (Read 264803 times)
Re: 571
« Reply #465 on: February 14, 2015, 10:32:12 PM »
Lol looks mean
Re: 571
« Reply #466 on: February 25, 2015, 01:42:52 PM »
overdrive pulley, new bracket on order. already have a new pump. Will check all clearances after install, along with squaring up the axles to the chassis, as first post-CA maintenance. Back at least to wreck-wheel status at that point.
need to see if I can find a carquest (and the receipt) to get core charge back, I think that was like $160 or something.
Re: 571
« Reply #467 on: March 10, 2015, 09:38:41 AM »
saving this for later... I kinda like the goatbuilt prewired option. need to look at my old wiring sketch, and compare this to the full breaker option.
http://www.pirate4x4.com/forum/electrical-wiring/1783897-sexy-waterproof-fuse-relay-box.html
Re: 571
« Reply #468 on: March 10, 2015, 09:45:16 AM »
wiring sucks..
Re: 571
« Reply #469 on: March 10, 2015, 09:46:10 AM »
bad wiring sucks.
Re: 571
« Reply #470 on: March 10, 2015, 09:50:08 AM »
had to rewire a lot of the mowzer. There was an unused hot terminal in the factory harness on the supply side of the breakers that has been fine for 50 years now, and shortly after moving things around fixing the steering box a couple weeks ago, it decided to arc out and melt two wires in the harness and give me a near-fire behind the dash late last week.
All better now.
Re: 571
« Reply #471 on: March 10, 2015, 10:05:19 AM »
not a single crimp connection on 928 or 572 seems to be working fine.  All solder and double heat shrinked
the only weekness in my wiring is how i connected to relays.  i think they will get soldered soon.  Had a spade terminal pop off once wreck wheeling.
Re: 571
« Reply #472 on: March 10, 2015, 10:07:06 AM »
you feeling okay? your spelling is even worse than usual this week  ;D
Re: 571
« Reply #473 on: March 10, 2015, 10:10:24 AM »
i dont know the CL responses must be getting to me
Re: 571
« Reply #474 on: March 10, 2015, 10:11:49 AM »
don't get too much of that on ya. hah
rio grande looks like a sweet drop top summer cruiser if the frame is whole!
Re: 571
« Reply #475 on: March 12, 2015, 01:52:56 PM »
some one stole your idea mike
Re: 571
« Reply #476 on: March 12, 2015, 02:14:55 PM »
Almost look like lull fenders. Sweet
Re: 571
« Reply #477 on: March 12, 2015, 03:27:44 PM »
just happen to notice on RCVs site one of the pics haha
Re: 571
« Reply #478 on: March 12, 2015, 06:08:15 PM »
Newer tractors have a similar setup but it's on a neat pivot that's spring loaded so the tire can turn full lock and the fender stops 75% or so of the way.
Re: 571
« Reply #479 on: April 29, 2015, 08:59:33 AM »
Power steering all set. Forgot I need to get a shorter belt. Arie I'll hit you up late this morning.
Everything else looks good at first glance. Light bar re mount, little lights are loose. Needs bolt and fluid check and tools packed.
I want some weatherproof 2 pin connections for my lights. Anyone have favorites or should I just get into weatherpack tools? Assuming they're rated for high enough current.
