Author Topic: 571  (Read 264891 times)
Re: 571
« Reply #405 on: November 26, 2014, 01:46:51 PM »
Very very true. I still need to do front axle seals too. Should get some 5.38s in there and use more third gear...
Re: 571
« Reply #406 on: November 26, 2014, 01:50:08 PM »
we will have a gear party one night in late Dec
572 rebuild and rear spool install
928 front and rear spools and 5.38's
571 gears!
Re: 571
« Reply #407 on: January 03, 2015, 12:54:30 PM »
Tires mounted. Need to hog out the wheels.
Re: 571
« Reply #408 on: January 04, 2015, 05:09:28 PM »
Pretty sure I found the funny front end noise.
Anyone ever get inner axle seals to live? Outer bearings took a BEATING from crap coming in the backside. Surprising still appear serviceable. I really really want a parts washer though. Really.
Re: 571
« Reply #409 on: January 04, 2015, 05:29:41 PM »
Don't know if these will work for you.  I'm going to run them.
http://www.ruffstuffspecialties.com/catalog/SEAL1.html
Re: 571
« Reply #410 on: January 04, 2015, 06:03:45 PM »
Sorry, I meant inner spindle seals. Axle seals are trashed too but I'm not as worried about them...  They live for a while sometimes as opposed to never ever living.
Re: 571
« Reply #411 on: January 04, 2015, 06:31:13 PM »
used winch. For sale cheap. Dfw.
Re: 571
« Reply #412 on: January 04, 2015, 08:23:38 PM »
Sweet find mark.
Never had good luck with spindle seals either... ever.
I just grease and or replace them often. Seems we do alot of wheeling in water I guess.
Re: 571
« Reply #413 on: January 04, 2015, 08:55:09 PM »
are the spindle seals and axle hat seals present?
we just clean and grease 3x a year and they last
nice winch
Re: 571
« Reply #414 on: January 04, 2015, 09:11:12 PM »
Its however you last assembled it. First time I've taken it apart IIRC. Parts were present just not sealing anymore.
Axle in/out without outer c clip probably doesn't help it
Re: 571
« Reply #415 on: January 04, 2015, 09:19:18 PM »
only the yukons run an axle c clip.  solids and fat girls dont.
Re: 571
« Reply #416 on: January 05, 2015, 10:03:35 AM »
Doesn't mean it isn't the reason. Axle walk is probably still a thing.
Anyone know what the difference in 14 bolt install kits is pre/post 1988 model year?
Yukon lists MK GM14T-B as '89+ and MK GM14T-A as '88-
No idea which I have. I'm getting install kits since I'm short on spare shims. Preload on the front is SUPER light BTW. Carrier and pinion installed and it'll coast for a full revolution. Feels like the pinion should without a seal installed, kinda funny :)
Re: 571
« Reply #417 on: January 05, 2015, 10:45:56 AM »
85' K30 should be your look up.
The first design was produced from 1973 to 1984. The first design remained unchanged until 1986. This design had drums that were held on by the wheel studs and had a smaller diameter pinion bearing than the second design. The second design was produced from 1986 to present. One change that occurred in the second design was that on some models the brake drum could be removed without having to remove the hub and axle shaft. Additionally, the pinion received a larger diameter bearing while the pinion stayed the same diameter, which increased the durability of the pinion. All these axle are full floating.
Re: 571
« Reply #418 on: January 05, 2015, 11:51:29 AM »
emailed motive gear... working on it
Re: 571
« Reply #419 on: January 05, 2015, 12:27:45 PM »
trail gear/longfield spindle bushings ordered. replace seal and bearing with a teflon piece. we'll see how they do; they're well-reviewed.
https://web.trail-gear.com/TG/Longfield_Dana_60_Spindle_Bushing__Teflon/i_0_0_/_301693-2-KIT.aspx
